5th Gen Caliper relocation bracket complete! (pics)
Old Mar 4, 2004 | 12:31 PM
Matt93SE's Avatar
STFU n00b!
Finally have my website back up and the pics are loaded.
http://www.mattblehm.com/HSS_images/...en_relocation/
As you can see, there's not a lot of room, but they DO fit behind factory 17" wheels!
I am also doing some intro pricing on these, as listed in this thread in the Group Deals forum:
http://forums.maxima.org/showthread.php?p=2766068
For you naysayers, this kit is NOT designed as an all-out track setup. This is designed for the average joe with larger rims that wants to have some better looks and get rid of the annoying rotor warpage problems common in the 5th gens. This will provide additional performance and stability over the factory system, without costing an arm and a leg. If you want a $2000 brake system, then you're going to have to pay for it. you can never get a free lunch!
Old Mar 4, 2004 | 02:04 PM
Larrio's Avatar
The Definitive AE Master
holy smokes batman!
but i still like my blehmco kit with 300zx calipers
Old Mar 5, 2004 | 09:00 AM
K Pazzo 6's Avatar
i'm in for this....dont need bbk right now, just need to get rid of current warpage
Old Mar 5, 2004 | 09:34 AM
BigDogJonx's Avatar
What does this actually do besides relocate the position?
Dixit
Old Mar 5, 2004 | 09:48 AM
Colonel's Avatar
Old Fuddy Duddy
Dixit
It relocates the caliper out to use larger rotors. Right now he is putting on the 12.6" rotors used on the 04 Max's. Better than the puny 11.9 or 11.8 (cant remember) of the stock.
I personally am also installing the 300Z calipers and SS lines on mine. I HATE the brakes with a PASSION.
Old Mar 5, 2004 | 10:01 AM
d_warner's Avatar
Old Timer
Loooks good Matt. Are those Franks Rims?
Old Mar 5, 2004 | 10:11 AM
BigDogJonx's Avatar
Got it, I thought it was just a relocation to the bracket to a slightly higher position, like 10-11oclock.
Dixit
Old Mar 5, 2004 | 10:12 AM
Matt93SE's Avatar
STFU n00b!
Yup!
Frank's rims on Mike's car!
Dixit, this uses the larger 2k4 Max rotors, and relocates the 5th gen caliper to fit. some pretty tight clearance issues there. wasn't fun getting the bracket to fit!
Old Mar 5, 2004 | 10:19 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Any difference in back spacing between the 2K-2K1 SE rims and those 2K2+?
I know the center caps/lugs are somewhat different, but wondering if 2K-2K1s could be slightly different with such close tolerances.
BTW, any idea what the weight difference is between the OEM 2K-2K1 rotor and the 2K4 rotor?
Is that going to noticeably increase stopping distance or is it negligible?
If you come up with a REAR kit, we'll all .
Old Mar 5, 2004 | 11:42 AM
kwd2kSE's Avatar
I'll help on some of the questions. The 2000/2001 front rotors are 11.0", so this is a BIG difference - these new rotors are 12.6". The stock 17's from 2000-2003 are all the same dimensions -back spacing, width, lug pattern. Yes the center caps, lugs, and finish varies, but its only cosmetic.
And yes, Matt and I are working on a REAR kit now. Definately a much tougher job. We have "Phase 1" detailed out but not ready to start production yet, working on "Phase 2"-which is the tough one.
Mike
Old Mar 5, 2004 | 02:54 PM
StrongIsleMax's Avatar
Do you know when Brembo, Powerslot, etc. are going to release an aftermarket rotor for the 2K4 Maxima?
They will probably be the same price or less than the OEm 2k4 rotors.
Old Mar 6, 2004 | 08:05 PM
Matt93SE's Avatar
STFU n00b!
There's one company out there right now that has them, and I'm working on getting some samples to take pics and such for you guys.
FYI, Powerslot uses Brembo rotors.. they buy brambo blanks, cut slots in them, and slap their sticker on it.
Old Mar 6, 2004 | 08:32 PM
Triple8Sol's Avatar
I miss the .org!
What type of rear kit are you developing? Would it utilize the stock caliper and/or rotor?
Old Mar 6, 2004 | 09:51 PM
young1976's Avatar
check this thread
http://forums.maxima.org/showthread.php?t=289318
Old Mar 7, 2004 | 01:02 AM
Triple8Sol's Avatar
I miss the .org!
Originally Posted by young1976
Matt93SE
May 24, 2019 02:58 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
