any how-to's on painting calipers?
Old Mar 8, 2004 | 09:05 AM
1NICEMAX's Avatar
i'm thinking of doing these on my free time. anyone know where i can find a write-up on these?
Old Mar 8, 2004 | 09:26 AM
wariow's Avatar
you don't need a write-up. Just remove teh wheels, cover the rotors witha big towel. And paint away. You can use either brush on caliper paint or spray.
Old Mar 8, 2004 | 09:42 AM
dmontzsta's Avatar
Ford Only.
Remove the wheel and mask everything off really well. Sand the caliper as much as you can. Get some grey engine paint and throw 2 coats on there for primer. Then get the color you want and paint away with as many coats as you would like.
Old Mar 8, 2004 | 10:31 AM
CanadianMoFo's Avatar
Lots of prep work = a great finish
Don't cheap out on the brake cleaner. Get a couple wire scrub brushes and go to work on whatever you can get off before you paint. It won't be spotless like new, but it should be relativly clean before you start to paint. The Folia Tec caliper paint is a great kit. A 2 part paint-laquer that gets mixed together before you apply it. It takes QUITE a while to dry so you'd need a garage to leave the car in while it drys/cures. The finish is excellent though.
CM.
Old Mar 8, 2004 | 02:53 PM
happyricefob's Avatar
V^___^V
[lazy sty-o]
1. remove wheel
2. put newspaper around the caliper
3. spray and pray
4. put the wheel back on
[hardworking sty-o]
http://www.motorvate.ca/mvp.php/300
follow mr. motorvate's instruction regarding brake disassembly, get brake cleaner and clean the surface really well, clean off all the dust, spray and pray, and then reverse order.
Old Mar 8, 2004 | 06:04 PM
maxmobile's Avatar
clean, clean, clean, use a wire brush, if you have a drill use the wire brush bit.... then paint..
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
beerman1378
Sep 8, 2015 02:19 PM
