no key hole!!!
Old Mar 13, 2004 | 02:00 PM
EZEMaxima's Avatar
no key hole!!!
no key hole on front door handles....
checkout more pics here!!!
Old Mar 13, 2004 | 02:04 PM
SuperChris's Avatar
Infiniti 35 Double G's
just don't let the battery go dead...
Old Mar 13, 2004 | 02:06 PM
EZEMaxima's Avatar
i just did the passenger side, driver side keyhole still exists...just like the 5th gens...hehe
Old Mar 13, 2004 | 03:05 PM
Maxima95Tuner
looks good mang... very clean
Old Mar 13, 2004 | 04:35 PM
RA030726's Avatar
I'm nutty for Nissans
i was thinkin the same thing. My sis has a 02 Sentra with only the key hole in the drivers door. Looks clean, but I was pretty mad when i went to unlock the passangers door with the key.
So all you need to do is add a piece of metal on the inside?
Old Mar 13, 2004 | 07:06 PM
ohannon7's Avatar
you have done some different things to your max, is that a speaker in the middle of your dash?
Old Mar 13, 2004 | 07:45 PM
Nismo's Avatar
do you have problems with the sun overheating those amps?
Old Mar 13, 2004 | 10:04 PM
EZEMaxima's Avatar
Yes it is!! but i'm currently stripping down the car to get it painted and my stereo would change a bit. That speaker would be gone and another speaker placed somewhere else. I still haven't decided the exact location. I have an audio control ESP-3 for center channel processing but it's not installed yet.
I've had them for almost two years now and the only problem i noticed was the terminals are starting to corrode. As far as the amps overheating...no, and i always play my stereo from moderate to high volume. I'm taking them off before i take my car into the body shop for painting, I'll be taking car of the corrosion problem. And also there will be a cover with cooling fans, i already have the drawings and measuremnet he cover. Fans will vent into the trunk.
Eric
Old Mar 13, 2004 | 10:11 PM
EZEMaxima's Avatar
That was the only thing the i noticed that was different between the two door handles. The mounting location was different for that side, so i fabricated a bracket with a small piece of sheet metal. Also i had to switch a plastic locking tab that hold the rod in place with the one that the front door handle had.
if you look at this picture, it's the green plastic clip that i had to use.(lower left)
Old Mar 13, 2004 | 10:28 PM
nismos14's Avatar
§è~® f®ÈÄk
hmm are the amps visible from the outside? that is a really neat idea
Old Mar 13, 2004 | 10:35 PM
azmaxipad's Avatar
hell ya looks pimp man
Old Mar 14, 2004 | 04:39 PM
Broaner's Avatar
2060lbs and falling...
And don't let the keyless fail.
Old Mar 14, 2004 | 05:18 PM
CCx's Avatar
CCx
Looks great!
Old Mar 14, 2004 | 05:19 PM
EZEMaxima's Avatar
amps are visible outside, so i cut a piece of black carpet to cover them temporarily until i get the time to fabricate the amp cover with fans.
Eric
Old Mar 15, 2004 | 09:40 PM
K Pazzo 6's Avatar
what is that in middle console???
Old Mar 16, 2004 | 11:24 AM
Nyc2kMax's Avatar
that's looks like a cd changer cool
Old Mar 16, 2004 | 02:00 PM
Conrad283's Avatar
I need a truck
Old Mar 17, 2004 | 02:50 PM
EZEMaxima's Avatar
That's my Sony DVX-100. It's a 10 disc CD/DVD changer. It also plays VCD but not MP3.
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 16, 2015 02:53 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
