Need new brake rotors, dont want stock....but on budget
Old Mar 24, 2004 | 06:23 PM
maxspeed96CT's Avatar
The original VQ...
I need new brake rotors. I dont have the money for a big brake kit or anything expensive but i want something better than stock. I hear to get slotted only and not drilled because they crack is this tru? I beat on my brakes bad .
Also are 2k2+ rotors bigger, and would i be able to use them?
Old Mar 25, 2004 | 06:30 AM
s0ber's Avatar
If you beat on your brakes then get slotted only... I doubt you would be able to use 2k2 rotors even if they are bigger, someone here would of mentioned it before :P
Old Mar 25, 2004 | 06:53 AM
Maxima-2's Avatar
I gotta suggest the brembro rotors with EBC green pads! They saved my life last night around 1:30 am when some fawking deer decided to play on the wet road.
Old Mar 25, 2004 | 07:09 AM
Conrad283's Avatar
I need a truck
I hear the Powerslot rotors are the best on the market right now
Old Mar 25, 2004 | 07:13 AM
s0ber's Avatar
I heard EBC greenstuff pads are good stuff :P
Old Mar 25, 2004 | 07:43 AM
RastaManMax's Avatar
Powerslot rotors are overpriced IMHO. If i was you i'd get a set of 4 slotted only Brembos and Axxis MM pads. I don't beat on my brakes regularly, so i went Xdrilled because they'll look good behind the Koseis. If you want quiet, go Reybestos Quiet Stop.
LEMAR
Old Mar 25, 2004 | 08:54 AM
EteRnity059's Avatar
Boosted?....
I just had my brembo blanks and porterfield R4-S install and theya re great. They definately bite harder than stock rotors and porterfields. Tire Race sells the rotors for $44 each for fronts and I thnk $54 for the rears. Great purchase and will go with them again. I debated on slotted but I don't want the slotts to eat away my pads.
Old Mar 25, 2004 | 09:16 AM
Nealoc187's Avatar
SLOW
Forget getting special rotors, just get some cheapo rotors and get some good pads such as Hawk HPS or Porterfield R4-S. Brake pads determine how well your car stops, not the rotors. Especially since you said you are hard on your brakes, I would definately not get slotted rotors for the simple fact that they are more expensive, will wear through your pads even faster than you do now, and won't improve your stopping at all unless you are doing stop after stop after stop like you would do on a road course and are getting a bunch of outgassing and glazing.
Old Mar 25, 2004 | 01:23 PM
The original VQ...
ya but witch pads are the best bang for the buck?
and im asking aboutt he rotors because i need mines replaced, they have a black stripe around them and are purple.
I just asked about he 2k2 rotors because i hear bigger rotors make a diffrance to.
Old Mar 25, 2004 | 07:05 PM
mitch33x's Avatar
get brembo blank, stock replacement rotors and Hawk HPS for front pads, or Porterfield R4S for front pads/rear pads. For spirited street driving, thats all you're gonna need
Old Mar 25, 2004 | 11:13 PM
If you're driving hard enough to cause that to happen your stock sized rotors will most likely warp anyways. I was assuming you wanted something that looked better than blanks hence i suggested slotted.
LEMAR
Old Mar 26, 2004 | 04:48 AM
The original VQ...
LEMAR
i only suggested slotted cause i thought they had much better cooling. I dont care much how it looks.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
