5th Gen springs on a 4th gen...
Old Mar 25, 2004 | 11:25 AM
nupe500's Avatar
Jedi Knight
ok...now from some previous posts, I think that I read that the front springs from a 5th and 4th gens are interchangeable. Can anyone confirm that? That would be a great help!
O
Old Mar 25, 2004 | 11:58 AM
happyricefob's Avatar
V^___^V
PM "regime" aka daniel. i believe he has 4th gen eibach on his 5th gen AE.
Old Mar 25, 2004 | 12:05 PM
NYCe MaXiMa's Avatar
yep, they are.
My friend has stock 5th gen springs from my 2k on his 96 in the front.
It 'seems' as if the car is more jacked up in the front though as it would be on stock 4th gen springs.. may have to do with 5th gens being heavier and designed to support more weight.. but it's not that big of a difference.
Also..
5th gen springs WILL fit in the rear on 4th gen struts.. the spring just narrows up a little at the bottom, and will have to "snap in" with a little bit of driving to sit in place on the 4th gen strut. I have 4th gen KYB AGX.
4th gen springs do NOT fit on 5th gen struts in the rear. But 5th gen springs on 4th gen struts do..
front is interchangible in every way.. 4th gen struts will have to be modified slightly to fit..
Old Mar 25, 2004 | 12:28 PM
nupe500's Avatar
Jedi Knight
well what I want to to is put 5th gen springs on the front of my 4th gen...do I need to modify anything?
Originally Posted by NYCe MaXiMa
yep, they are.
Also..
Old Mar 25, 2004 | 01:04 PM
nope
front springs are the same.. the top coil of the 5th gen spring is kind of flattened but it doesn't matter..
they fit the same
just the way the car will sit 'may' be a little bit different.. but it can just be in my head too..
Old Mar 25, 2004 | 07:05 PM
nupe500's Avatar
Jedi Knight
kool...thanx
Old Mar 27, 2004 | 10:34 AM
driver824's Avatar
correction. the frts are the same the rears are not and will not fit in... i had maxspeeds but got sent the wrong ones. they were for 5 gen. they never "sat" correctly. all they did was begin to push out. almost had alot of porblems.. but got a new setup b4 that happened..
blake
MAXSE5SPD
Sep 17, 2022 04:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
