My AE headlights!
Old Mar 27, 2004 | 02:02 PM
gsumax's Avatar
My AE headlights!
EDIT: post made by Bijan, sorry for the comments
Thanks to Bijan for helpin me out, it turned out better than I thought it would. I was up all night thinking about him.
I think it matches my black GLE very well. Very "stealth" appearance. Igor can shove it.
Old Mar 27, 2004 | 03:13 PM
Cutler's Avatar
Why would you care what Igor thinks?
Old Mar 27, 2004 | 03:25 PM
gsumax's Avatar
He called me a bish...
Old Mar 27, 2004 | 03:34 PM
1FSTMAX's Avatar
Looking good.
Old Mar 27, 2004 | 03:45 PM
MaximaRider's Avatar
Nice ride, looks dope!
Old Mar 27, 2004 | 03:53 PM
Conrad283's Avatar
I need a truck
Those headlights flow very well with the car
Old Mar 27, 2004 | 04:38 PM
Max03girl's Avatar
very nice.
Old Mar 27, 2004 | 07:35 PM
|Bijan|'s Avatar
UCF Lexus
holla dolla colla
Old Mar 27, 2004 | 07:38 PM
gtr_rider's Avatar
192.168.1.1
I like...
Old Mar 27, 2004 | 07:51 PM
|Bijan|'s Avatar
UCF Lexus
Luke, you gotta add that to the DIYs on vqpowah!
BEFORE: ----------------------------------------------------------------------- AFTER:
Old Mar 27, 2004 | 07:55 PM
Taken2DaMax's Avatar
That looks fookin tight...i wish i had a 5th to that same thing.
Old Mar 27, 2004 | 08:00 PM
gtr_rider's Avatar
192.168.1.1
im on aim
Old Mar 27, 2004 | 08:06 PM
FanaticMadMax's Avatar
It looks really good, I'm planning to get mine done soon as I scrouge up some cash to get AE lights
nupe500's Avatar
Jedi Knight
bery bery NICE!
Old Mar 27, 2004 | 08:11 PM
|Bijan|'s Avatar
UCF Lexus
WTF? Paint only cost $3.99 -- the hell are you talkin about?
Old Mar 27, 2004 | 08:25 PM
Flava_24/7's Avatar
Boosted Panda
I agree, the clears upfront stood out more. The AE versions make your car look sooooo clean.
The set up you have is Fawking Dope!
Old Mar 27, 2004 | 08:29 PM
Nismotic's Avatar
Always sunny in philly
you bish...
LoL- looks tight.
Old Mar 27, 2004 | 08:35 PM
|Bijan|'s Avatar
UCF Lexus
Originally Posted by gtr_rider
im on aim
uhh, away message much?
Old Mar 27, 2004 | 09:24 PM
maxspeed96CT's Avatar
The original VQ...
looks hot , those rims match the max perfect too
Old Mar 27, 2004 | 09:30 PM
happyricefob's Avatar
V^___^V
nice man...your car looks hot
Old Mar 28, 2004 | 04:55 AM
Kevlo911's Avatar
Kevlo for President
Your whole car looks nice.
Old Mar 28, 2004 | 09:25 AM
3.0HO
Nice ride! Some chrome side mirrors (cefiro a33) would look so sweet. S4 style.
Old Mar 28, 2004 | 10:07 AM
driver824's Avatar
its amazing how much a little paint can do...
good job..
blake
Old Mar 28, 2004 | 01:24 PM
gtr_rider's Avatar
192.168.1.1
Old Mar 28, 2004 | 02:54 PM
Ludacris's Avatar
Looks sweet
Old Mar 28, 2004 | 03:29 PM
frankieduxAE's Avatar
that's a great DIY. It may get as popular as the fog light DIY.
nice ride.
Old Mar 28, 2004 | 05:04 PM
PearlWhtMaX2000's Avatar
wow i would love to do that!! was it hard?? any write ups??
Old Mar 28, 2004 | 11:12 PM
RastaManMax's Avatar
Now that's aggressive. Good job
LEMAR
Old Mar 29, 2004 | 03:15 AM
metallic97gxe's Avatar
Master Will
looking very nice..................
Old Mar 29, 2004 | 07:39 AM
greekmax2k1's Avatar
love the lights... i wish i had a stillen kit....nice job
Old Mar 29, 2004 | 07:46 AM
any write ups??
Old Mar 29, 2004 | 09:08 AM
gsumax's Avatar
Originally Posted by PearlWhtMaX2000
any write ups??
Check out Studmans write up for more indepth info
1) Open the oven and move the rack to the lowest position.
2) Warm up the oven to 250 degrees.
3) Remove all light bulbs from the headlight.
4) Remove the ballast from the housing.
5) Remove the 3 small screws around the edge of the housing where the clear meets the black.
6) Wet a bath towel and ring out all excess water.
7) Place the towel on a cookie sheet with the excess hanging off the side.
8) Place the headlight on the towel with the clear side towards the cookie sheet.
9) Wrap the wet towel around the headlight. You should end up with 2 layers (the ends) of the towel where the clear part of the housing is.
10) Put the cookie sheet in the oven and bake at 250 degrees for 35 minutes.
11) Remove from the oven.
12) Remove the towel and light from the cookie sheet.
13) Un-wrap the towel from the headlight.
14) Wipe off the condensation from the headlight.
15) Using a regular-sized flat-headed screwdriver (or old-school butter knife that you don't want), pry the black surrounds away from the clear lens. You'll almost think that you are breaking it, but it's flexible enough not to break unless you put alot of force on it. Start at the bottom of the light (if it were mounted on the car) and work towards the hi-beam side. The corner-light side will be last.
16) After you have pried all the little tabs out, gently but firmly pull the clear cover away from the black backing. Pull the pieces apart as if you were peeling apart 2 pieces of bread on a sandwhich.
17) When you get to the corner-light side, put the corner-light side downward. Pull the hi-beam side's ends apart from each other, as if you were "splitting a wig". The corner-light end will come apart with little-to-no hassle.
Reinstallation instructions should be the exact reverse, but I haven't made it that far, so I can't say that they really are.
personally, i cooked the lights for 25 minutes and it was more than plenty, they came apart easily.
good luck
Old Mar 29, 2004 | 09:38 AM
so to put them back you cook them again or no?
Old Mar 29, 2004 | 09:44 AM
gsumax's Avatar
yeah, to put them back, put the headlight back together as much as you can, and but it in the oven again for about 15 minutes, same temp. and then take it out and push it together as hard as you can, making sure it seals up good.
Old Mar 29, 2004 | 03:16 PM
Max4Speed's Avatar
www.autotalk.com
Now if you can get some 2k2 Heads :-) Looks slick btw. Welcome to the club!
Old Mar 29, 2004 | 05:26 PM
|Bijan|'s Avatar
UCF Lexus
AE club of ATL
Old Mar 29, 2004 | 06:50 PM
ohannon7's Avatar
Awsome, your car is sick!!!!!! I like the stance of your drop too, its more aggresive lookin than most..... what set-up do you have?
Old Mar 29, 2004 | 06:57 PM
gsumax's Avatar
thanks, i have teins
Old Mar 29, 2004 | 07:08 PM
ohannon7's Avatar
oh, thats it. Ummmm it looked different, looks kinda lower in the front. Or is it just the pics
Old Mar 29, 2004 | 07:38 PM
gsumax's Avatar
yeah, the car is sitting on somewhat of a slant, making the front look lower
