Hmm, Octane use w/ the Max...
Old Apr 4, 2004 | 05:35 PM
|Bijan|'s Avatar
UCF Lexus
Uhm, soooo -- what octane do you use? Whenever I fill up, as in...when I'm literrally on "E"...I use premium (93).
Does a Maxima NEED premium at ANY time? Is it just wasting $$? From what I know, premium burns cleaner and doesn't have any...or LESS additives compared to a lower octane. More power.......I doubt it...
Is 87 octane ALWAYS good? Whats yalls $.02?
Old Apr 4, 2004 | 05:44 PM
VQvroom's Avatar
for the maxima- 93 all the time every time.
when i drove my old 4cly with 87 i could hear the valves ping. so i used 89 most of the time. i could feel the difference between gases.
Old Apr 4, 2004 | 06:01 PM
MrGone's Avatar
christ sake search.
Old Apr 4, 2004 | 06:04 PM
BigDogJonx's Avatar
I believe if you are straight NA, no need for it. The maxima has a fuel map for that octane and I believe is fine.
Now if you are boosted like me, running 87 is bad idea. Unless of course you got the J&S and want to run cheap gas.
Dixit
Old Apr 4, 2004 | 07:44 PM
sk24iam's Avatar
93 all the time. Around here its up to 2.07/gallon
Old Apr 4, 2004 | 07:58 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
sunoco ultra 94 baby 1.93 a gallon
Old Apr 4, 2004 | 08:33 PM
white m3 guy's Avatar
unfortunatley maxima's need high octane to perform the way they do, you can try using 89 it will give u more gas milage but your car will drive like crap
Old Apr 4, 2004 | 08:35 PM
NickStam's Avatar
I love how this thread comes up 700 times a year.
Old Apr 4, 2004 | 08:36 PM
I30tMikeD's Avatar
I can't believe a member who is able to search is asking this question.
Old Apr 4, 2004 | 08:38 PM
NickStam's Avatar
good point, 1 week ban
Old Apr 4, 2004 | 09:12 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
YOU HAVE GOT TO BE FRIGGIN KIDDING ME!
Old Apr 5, 2004 | 12:47 AM
SEDaveMax's Avatar
Crappy California 91 is $2.37 per gal at Chevron in my neck of the woods!
Old Apr 5, 2004 | 06:43 AM
Blaxxxima's Avatar
!OG SNES OG!
to the moon, Alice!
Old Apr 5, 2004 | 06:56 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
gaining "donating status" doesn't cure laziness
Old Apr 5, 2004 | 08:15 AM
|Bijan|'s Avatar
UCF Lexus
Ha, well as I posted in feedback...when I try to search...I get this wack error message. "Fatal error 249027402.2492........."
Old Apr 5, 2004 | 08:18 AM
|Bijan|'s Avatar
UCF Lexus
oh, and I filled up w/ Shell 93....got 340 miles to a tank. -- I guess that commercial WAS right
Old Apr 5, 2004 | 09:54 AM
schernov's Avatar
Premium 1.79/galon at Costo
Old Apr 5, 2004 | 10:51 AM
Stephen Max's Avatar
Knock sensor equipped vehicles are programmed to provide maximum timing advance (and therefore power) based on a high octane fuel, typically 93 octane. Maximum power occurs at the onset of knock, so timing is set based on engine testing to just below the knock threshold. If the car owner chooses to use lower octane fuel, detonation (knock) will occur which the knock sensor detects, and the ecu will retard timing until knock is not being detected. So yes, power is lost when you fill up with lower octane fuel.
Old Apr 5, 2004 | 11:00 PM
mmmm840's Avatar
Just use Premium gas and be done with it.
Old Apr 6, 2004 | 12:58 AM
† ErV †
assuming there is a 10c difference between regular and premium, which is usually not 10, but 8, but ill put it 10 for illustration purposes, and assuming you fill up with exactly 18 gallons then, you are spending a whopping
$1.80 per tank
more
than you would have if you use regular.
so if you use 7 tanks per month, which is probably too generous, at the end you will *WASTE* that much money:
$12.60
which is about the cost of a meal for two people at your local junk food joint.
Old Apr 6, 2004 | 06:57 AM
SteVTEC's Avatar
search works just fine for me. try narrowing your search to a specific forum (4th gen) or to only in the past 6 months. there are 113 threads with the word "octane" in the title.
Old Apr 6, 2004 | 03:26 PM
|Bijan|'s Avatar
UCF Lexus
d'oh..................
JoshG
51
Sep 21, 2015 10:41 PM
cruce91
Sep 20, 2015 10:23 AM
Slamrod
Sep 3, 2015 07:38 PM
sdotcarter
Sep 2, 2015 09:53 PM
Team STILLEN
Aug 10, 2015 04:29 PM
