Dissassemble front susp. w/o losing current alignment specs
Old Apr 9, 2004 | 07:51 AM
mymaxlvsattn's Avatar
slackass
ok guys (and girls) I have a question for you
Anyone have any ideas on how to mark my current Camber/Toe settings on my front suspension? because i need to dissassemble my front 2 struts and I just got put in alignment about 3 weeks ago. that 60 bucks adds up.
So far I've had the idea of using a junkyard pen to mark around the lower strut bolts, but im not entirely sure that will work>
any ideas, suggestions, and imput would be appreciated.
Old Apr 9, 2004 | 08:27 AM
Jeff92se's Avatar
I'm needing a caw
You can get it ballparked but not totally accurate. But I've done struts and not needed an alignment
Old Apr 9, 2004 | 11:45 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
It's really a hit or miss thing, in all honesty. The more suspension swaps you do, the easier it will be...
Old Apr 9, 2004 | 01:12 PM
UncleMax98's Avatar
Unless you change the car height or have camber bolts, alignment should not be affected. There is no camber adjustment for stock bolt, and the toe setting is locked with a jam nut at the tie rod end.
Old Apr 9, 2004 | 08:33 PM
nick's Avatar
re
There is room for camber adjustment - with the lower bolt loose there is about 1/2" of movement - with lowering springs you want to pull the rotor toward you as much as possible.
Just mark your present settings with marker/knife - anything that will mark it nice and close, when you put things back together try to get them lined up as much as possible - it is trial and error method and you'll only get better with practice. I remember one week in summer in which i had my fronts dissasembled atleast 5 time in a week !!!
Nick.
Old Apr 9, 2004 | 08:42 PM
Jepht20's Avatar
Custom User Title...
Nick.
that's impressive and dedication!
i'm getting an alignment next weekend when my summer wheels get back on and two new(to me) tires mounted and then hope i don't need to again later in the summer if/when i can afford springs and front struts.
Old Apr 9, 2004 | 09:49 PM
slackass
NICE!
thanks for all the info...
Old Apr 11, 2004 | 10:15 AM
Jatan's Avatar
If you got the alignment done 3 weeks ago, did it come with any warranty? Around here it's usually 6 month/6000 miles.
Old Apr 11, 2004 | 02:38 PM
slackass
No warranty...and they didnt even give me a printout of my specs.
ah well. Mistake on my end. You live and you learn. Right?
Matt93SE
May 24, 2019 02:58 PM
vybz05
Dec 10, 2015 07:38 PM
homeyclaus
Sep 3, 2015 06:15 PM
Flores94
Aug 11, 2015 12:53 PM
Team STILLEN
Aug 10, 2015 04:29 PM
