I got addco bushings
Old Mar 22, 2001 | 03:51 PM
mzmtg's Avatar
Minister of Silly Walks
I went to autozone a splurged the $7.99 for addco general purpose urethane sway bar endlink bushings. You get 8 of them ,but the max only needs 4. I jacked the car up and ended up having to cut about 1/4" off each bushing for them to fit.
Anyway, I can feel a little more quickness in the roll stiffness. Plus, my old rubber ones were all rotted anyway.
So, if you have eight bucks burnin a hole in your pocket and time to kill...go for it.
Old Mar 22, 2001 | 08:17 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
how hard
How hard are they to install and why are they located, i think that's my next mod.
________
UrChocolateDream
Old Mar 22, 2001 | 08:35 PM
mzmtg's Avatar
Not hard to install at all. Take off both front wheels (you need to do both at the same time, if you do one side of the bar at a time you'll preload the bar...and thats bad). You will see where the sway bar attatches to the lower control arm just inboard of the hub carrier. Remove the nuts (14mm) on both sides and rotate the bar up off the end link. Swap the bushings and reverse.
Old Mar 23, 2001 | 06:42 AM
95Max's Avatar
If you are looking for bushing go to suspension.com They have both the end-links and sway bar bushing that are designed for our cars. They also have great prices I got both end-links and swaybar bushing for about 20 bucks.
Starrider
Dec 18, 2015 04:43 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ColdCananda
Sep 20, 2015 10:45 PM
