clutch......... problems
Old Apr 30, 2004 | 08:00 PM
AnDyMaN's Avatar
for those that decide to read this thread, im wondering if anyone can help me out. my clutch, which has been adjusted so that it does not have to travel as far as it used to, likes to... move the engagement point when i drive. it seems to switch after about every 100 or 200 times i press the clutch. the first 100-200 times i press it, it is really short, and really nice/easy to drive. then the clutch slowly moves the engagement point farther back (have to depress farther which makes me ride the clutch, AHH) and the initial resistance of the clutch, when pressed, is greater..... anyone know what this could be....? would bleeding the clutch help? maybe there is some air in there that is moving around?
ps. the clutch is not engaged when it is fully depressed... fyi.
thanks all
Old May 1, 2004 | 07:17 PM
AnDyMaN's Avatar
bumpit itit
Old May 3, 2004 | 07:45 PM
AnDyMaN's Avatar
lets do this again
Old May 4, 2004 | 02:30 AM
Ladzio's Avatar
Is it stock that came with the car or aftermarket..?
Old May 4, 2004 | 09:48 AM
AnDyMaN's Avatar
yea, the clutch is the stock clutch
Old May 4, 2004 | 10:07 AM
Ladzio's Avatar
I am not sure what problem might be, just getting information to make it clear for those who could advise. If clutch engages very early, it might be something internal, that the problem I have. My fork (lever the push rod of slave cylinder pushes) is very loose now and clutch inoperative at all.
Old May 6, 2004 | 07:54 PM
j_bryan's Avatar
Have you checked the clutch fluid level? Did you observe and leaks under the car?
Old May 7, 2004 | 06:46 PM
AnDyMaN's Avatar
a hah! a response, thank you... umm..... i didnt notice any leaks... my garage does not appear to have any unsual marks on it.... where is the fluid for the clutch located? thats what my friend thought the problem was also....
Old May 7, 2004 | 07:36 PM
nismos14's Avatar
§è~® f®ÈÄk
there is a shaft that can be adjusted i bet the screw on one side is loose and the shaft rotates slowly and moves in different directions check and make sure everything is tight there.
Old May 8, 2004 | 03:38 AM
Ladzio's Avatar
??? what are you talking about? What shaft? Clarify plz.
Reservoir is right behind brake fluid reservoir on top of clutch master cylinder.
Old May 8, 2004 | 11:15 AM
nismos14's Avatar
§è~® f®ÈÄk
its like a big bolt that has 2 nuts on it that hold a piece on it in one place check it out
Old May 8, 2004 | 11:41 AM
Ladzio's Avatar
Are you talking about adjusting the clutch pedal or what?
Old May 8, 2004 | 12:10 PM
nismos14's Avatar
§è~® f®ÈÄk
yea but if the bolt is not bolted up on both sides, the clutch will grab at different heights
Old May 8, 2004 | 12:18 PM
nupe500's Avatar
Jedi Knight
...cheeck that..
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
