Driving with brights on
Is driving with your brights on illegal? I ask because after I did the 9004 to 9007 conversion, my regular lights are "off" so, I get "brighted" by oncoming drivers. I should proably reaim them but I don't have time right now. So in the mean time, will I get ticketed by a cop because he/she thinks I'm always running brights?
~THT
~THT
I think it depends by state, but at night, you could theretically get cited for not turning off your high beams. I assume that you haven't switched the wires around for your low and high beams when you converted (or at least this is what I've been told needs to be done when converting...I yet to try this myself). How are you liking the 9007's BTW? Any improvement?
S
S
The 9007s kick butt compared to the 9004s. The pattern is much much better. I didn't know we were supposed to switch any wires besides the neg and ground. Time to go through that thread again.
~THT
~THT
Originally Posted by Vlad
Pop your hood. Look at headlight hoisings. You will see two black screws on each housing sticking out like 2 inches. One regulates horizontal tilt, other vertical. Have fun!
What I heard: It's very difficult to aim modern headlamps, body shops spend $1000-$3000 on a headlight aim system......
I don't think this can be done in your home garage
I dunno--my grandpa said you park on a level driveway and shine the lamps at the garage door. Maybe those days are gone with the sealed beams.....
Originally Posted by EvilRoadsVictim
The time you wasted posting this would have been less than going out and actually fixing your improper equipment. Blinding other drivers with your full knowledge and a lame excuse like "i don't have time" to turn a **** is perversive.
to write him up.
Figured out which "****" controls the vertical axis however, here's the dilemma: My driver-side adjuster doesn't want to turn either way. I've tried a screwdriver and pliers but to no avail. My passenger-side adjusts but it won't go any lower than it's currently set. Any suggestions?
~THT
~THT
Originally Posted by Frank Fontaine
Common sense: it ain't rocket science
I have never had a problem aiming my headlights...even with my cefiro one pieces.
Okay, so am I retard? I know the ***** by the radiator adjust the vertical axis but regardless of which way I turn them, the lights fail to move one way consistently. For instance, if I turn it clockwise, the beam goes down. But if I continue to turn it, the beam comes back up. What am I doing wrong?
~THT
~THT
Mar 12, 2020 12:06 AM
sdotcarter
Sep 2, 2015 09:53 PM
