Auto Transmission Cooler
Old Jul 23, 2004 | 07:46 PM
bostonmax84's Avatar
I am thinking about buying an auto tanny cooler for my 01 Max because I want the car to last as long as possible. To the people who have an auto tran cooler, is it worth it? Did it make your transmission shift smoother? Will it help avoid slipping? Thanks
Old Jul 23, 2004 | 08:25 PM
THT's Avatar
THT
Throbbing member
I have one but didn't notice any difference in shifting. And yes, it will help prolong the life of your tranny by reducing the heat of the fluid.
~THT
Old Jul 24, 2004 | 10:15 AM
passEMonTHErite's Avatar
How tricky is the installation? Do you use the existing hoses that run to the radiator? What about mounting, I would assume there is some drilling involved? Also, would I be able to do the drop resistor mod, or manually shift through the gears with a little more peace of mind?
Old Jul 24, 2004 | 10:58 AM
THT's Avatar
THT
Throbbing member
Very easy to install. I followed the directions found in the 4th gen How-to sticky and was done in about an hour and that includes doing a transmission fluid flush. I used new hosing that I bought at the time I bought the cooler. No drilling involved; you mount it by attaching it to your existing radiator. And yes, you could do the DR mod/VB mod with less worry; these tranny coolers are supposed to drop the temperature of the fluid by 60-70 degrees.
~THT
Old Jul 24, 2004 | 11:59 AM
Kevlo911's Avatar
Kevlo for President
http://www.bulkparts.com/MM001.ASP?pageno=1181
I have hte 403
Old Jul 24, 2004 | 12:27 PM
THT's Avatar
THT
Throbbing member
You can get the 403 at Autozone; no wait and it's the same price as most online retailers.
~THT
Old Jul 24, 2004 | 04:39 PM
blaze0ne
i was thinking bout getting this one:
SuperCooler 24,000 GVW
http://www.jegs.com/cgi-bin/ncommerc...28&prmenbr=361
how does this one compare to the 403?
Old Jul 25, 2004 | 05:31 AM
Kevlo911's Avatar
Kevlo for President
I have read the B&M style coolers, cooler better than the Hayden style coolers. I don't know if it is worth $50, but it is your money so you can get that or the 405 or 406 which should be around 24,000 GVW
tarun900
19
Dec 20, 2021 06:57 PM
BobTX10
Oct 7, 2015 08:43 AM
Pied
Sep 26, 2015 03:29 PM
