Big Brakes and clicking noises..
Question what would cause a big brake kit to clunk when the car is rolling back? A friend of mine has a Big brake which consists of AP 4 piston calipers, 2pc rotors, and stainless steel lines. Any time the car is backed up it makes a clicking or clunking noise. It's like one clunk per revolution. The noise comes from the front, on both sides.. Everything is torqued to spec, and have double checked everything to make sure it's installed properly according to the installation guide. This noise only occurs when the car is going in reverse, not foward.
Any thoughts or ideas are welcomed.
Thank you,
Alfonso...
Thank you,
Alfonso...
I too have noticed this and I'm not quite sure what causes it either. However, mine occurs under normal braking when coming down a pretty long (probably 1/5 mile) steep downgrade and I make a turn after my stop. I apply brakes periodically on the entire length and with the most pressure nearing the end of the length because the road is curvy and steep. It doesn't occur on level ground, going backward or anytime else. I notice mine predominantly from the driver's front and it goes away after about 5 seconds..probably 15 revolutions. I have the 4 POT Brembo Gran Turismo kit with the same specs as your friend's and I too have double checked everything. Other than under these conditions, which doesn't happen all that often the brakes perform just fine.
It's probably the pads moving around in retainers... there's always a little bit of clearance... it happens when you change "directions" of the rotation and sometimes when you come to a complete stop (rarely)... nothing to really worry about.
Depends on the Wilwood caliper but there is usually a "spring" guide/clip on both the leading and trailing edges of the pad backing as well as a bottom "tab" / upper pad hole for a guide...
jmlee44
10-02-2022 02:13 PM
04-16-2020 05:15 AM
HerpDerp1919
09-29-2015 02:02 PM
