noisy start ups in morning
Old Aug 21, 2004 | 05:17 PM
xxdean057xx's Avatar
what is causing this slight squeel? it seems to only appear when the car is cold. can anyone help?
Old Aug 21, 2004 | 05:18 PM
maximka's Avatar
same here ...
Old Aug 21, 2004 | 06:11 PM
Ant96GLE's Avatar
Its your belts, check to see if they're tight, if not tighten them up a little, make sure they're not cracked
Old Aug 21, 2004 | 06:14 PM
Torkaholic's Avatar
I concur. It's most likely a very slightly loose belt. Once it and the engine warm up a bit, it gets better "traction" on the pulleys and stops making noise. It's important to get this corrected relatively quickly, or the belts will develop a glaze on their surface which will make the problem worse, and requirement replacement vs. simple adjustment.
Old Aug 22, 2004 | 04:30 PM
Frank Fontaine's Avatar
I actually get the opposite now--when turning off, I hear a rattle. I'm thinking mine is the muffler because the whole outside has rusted away and is gone. But I hope it's not a rattle in the CAT......95k by the way.
Old Aug 23, 2004 | 06:24 AM
is it hard to tighten the belts? should i just replace it if i have to take it apart?
derekinthez
Nov 13, 2022 04:00 PM
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
