AC Question regarding circulating the air
Old Aug 22, 2004 | 05:34 PM
fadeaway's Avatar
Go Hokies!!
I'm looking to prove my friend wrong.
He always wants to press the button to "use only air from inside car", instead of using the air from outside. He says the AC will be colder since it doesn't have to take the hot air from outside.
Is he wrong?? Hmm. Then wouldn't all the air from inside the car be all nasty with everyone breathing (and farting)?
Hmmm.
Appreciate any advice. Thanks.
Dan
Old Aug 22, 2004 | 06:06 PM
† ErV †
No. I use the recirculate 99% myself otherwise all the crap from outside gets sucked in.
Your friend is correct.
Old Aug 22, 2004 | 06:12 PM
fadeaway's Avatar
Go Hokies!!
Really? Hmm. Oh well.
Old Aug 22, 2004 | 11:17 PM
Nismo's Avatar
on the highway I use fresh air, moving car seems to force more air though the cowling at that speed
Theres a difference between cooler air and stinky air,
Personally I have mine on fresh air 99% of the time, not because its colder or hotter, I just leave it that way unless I pass by a farm or a POS with smoke comming out of his exhaust then I hit the recurculation button.
Old Aug 23, 2004 | 04:34 AM
Matt_NZ's Avatar
Your friend is correct Makes sense if you think about it, when its recirculating, it's cooling air that has already been cooled, so makes sense that it's going to be colder then it constantly cooling hot air.
When ever I'm in the city, I'll have it on recirculate, can't stand the fumes from cars, gives me a headache
Old Aug 23, 2004 | 07:00 AM
mzmtg's Avatar
Minister of Silly Walks
Don't leave it on recirc too long. You 'll pass out from lack of oxygen.
Conversely, don't leave it set on outside air too long either. Pressure will build up and the car may explode.
Old Aug 23, 2004 | 07:19 AM
fadeaway's Avatar
Go Hokies!!
I guess it's a catch 22 either way
But does anybody notice any temperature differences between the 2? For some reason I thought when recirculate was on, the air was a bit less cooler.
Old Aug 23, 2004 | 08:01 AM
mzmtg's Avatar
I know my car cools of A LOT faster when set to recirc. On hot days, the AC cant even keep up when set to outside air.
Old Aug 23, 2004 | 10:30 AM
Stephen Max's Avatar
It really makes a difference when it is humid as well as hot. When you turn the AC on, the first thing that happens is the AC removes the moisture from the air. Once the humidity inside the car is reduced to a certain level that has a name and I can't think of (dewpoint, maybe?), then it removes heat. So if you are constantly replenishing the interior with humid air, the AC will expend a certain amount of energy trying to remove the humidity rather than cooling the air.
I don't think cars are sealed so well that the occupants can suffocate.
Old Aug 23, 2004 | 11:22 AM
Zero Deuce SE's Avatar
It's not the suffocation that you need to worry about. It's the oxygen depleted air inside the cabin. With a car full of people, the oxygen will be replaced by carbon dioxide in short order. Some owner's manuals even say not to leave it in recirc too long.
Old Aug 23, 2004 | 11:32 AM
mzmtg's Avatar
Your car has enoughholes in it that you dont need to worry about running out of oxygen.
Seriously.
Old Aug 23, 2004 | 11:49 AM
Isn't that the definition of suffocation?
I really, really seriously doubt any car would be designed so that the occupants can suffocate if the recirc is left on too long. Maybe in a world without lawyers.
Old Aug 23, 2004 | 11:58 AM
Yes, I suppose it is. I was trying to say that most people would start to feel funny before they actually passed out from too much carbon dioxide. I was thinking too far ahead thinking that suffocation resulted in death.
Old Aug 23, 2004 | 01:24 PM
slizan99's Avatar
the air temp at the center vent on fan setting 2 is usually about 5 degrees cooler when set to recirculate. the hotter and more humid it is outside, the bigger the output temp difference is. (in favor of recirculate)
Old Aug 23, 2004 | 06:41 PM
† ErV †
On a side note, if you have farting friends even a doorless car won't save you from it...
So in this case it doesn't really matter what mode you use. I am just picky about outside smells like exhaust.. bleh
Old Aug 24, 2004 | 06:09 AM
2k2kev's Avatar
It's chrome alright...
The first few times it was funny, now you're starting to look like you really think that could happen
BTW, Stephen Max is right.
Old Aug 24, 2004 | 07:34 AM
It could happen. How long do you want to breath stale air?
Old Aug 24, 2004 | 07:50 AM
2k2kev's Avatar
You're scaring me, and it has nothing to do with stale air.
Old Aug 24, 2004 | 07:52 AM
No need to be scared my son.
Smackasmith
Feb 1, 2016 12:40 AM
conansriver
Sep 11, 2015 10:26 AM
lux97Max
Sep 4, 2015 05:42 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
