Snafu with Big Brake Install
Old Apr 6, 2001 | 03:50 PM
Chunger's Avatar
My other car is a Hybrid
Well it looks like a few washers are needed to move the caliper out about 2.5mm (1/4")... or the rotor disc needs to be moved inboard (via the hat). I haven't tightened down everything yet because I need to go out to buy a hex socket to fit the dang bolts... but I'm pretty sure about the needed fix...
BTW... the new rotors still appear lighter than the Stillen Crossdrilled ones... I'll bring a scale soon...
My recommendation to those who bought the kit... hold off your install until I figure this out... unless you don't mind having your car down a little while...
For a sneak peak....
ROTOR COMPARISON
MOUNTED KIT
Old Apr 6, 2001 | 03:52 PM
Jeff92se's Avatar
I'm needing a caw
Can you take a pic of the adaptor bracket? Thanks and good luck on the install.
Old Apr 6, 2001 | 03:57 PM
Chunger's Avatar
The washers are going between the bracket and the CALIPER(corrected).
I'm documenting it all... will post instructions upon completion... gotta go to autostore now...argh!
BRACKET REAR VIEW
Old Apr 6, 2001 | 04:14 PM
Confused's Avatar
Permanent Maxima.org Resident
rotors are about
10.5 - 11 lbs
nice pics... spoke too soon in the other thread..
Old Apr 6, 2001 | 06:01 PM
NickStam's Avatar
Re: rotors are about
Not that it's a big deal, but it seems like this isn't a 'open up the box and bolt on' kinda mod. Maybe the manufacturer can fix this bug?
Old Apr 6, 2001 | 06:12 PM
Chunger's Avatar
OK back to work on the car again...
Brian called me from Atlanta to help me out... that was cool of him to do...
Daylight is about gone... but I WON'T BE BEAT!
Old Apr 6, 2001 | 07:12 PM
OgreDave's Avatar
Cant wait to see them behind the tires
Old Apr 6, 2001 | 08:04 PM
Chunger's Avatar
OK... finally done with one side... with exception of hydraulic part (yes... I know it's important too!)... Ran out of light...
I ended up mounting the bracket INBOARD of the original mounting points...
BRACKET REAR VIEW
Notice that I had to remove the lower strut bolt to mount caliper...
I still had to stack 2 small washers on each mount... between the caliper and new bracket to center the caliper over the rotor...
CENTERED SETUP
I put my wheels back on...
VIEW WITH 18" WHEELS
I picked the right rim to show off the WILWOOD logo..hehe
CLOSE UP
I also have my stock 16" SE rims... maybe put them on later..
MORE TO COME TOMORROW>>> It's suppose to rain.... oh well...
Old Apr 7, 2001 | 10:59 AM
Maximamike's Avatar
Sweetness!
Old Apr 7, 2001 | 06:21 PM
Chunger's Avatar
It finally stopped raining at noon...
I finally finished up the driver's side...
Just got to hook up the brake line on the passenger side then bleed the system...
FINAL PRODUCT
Old Apr 7, 2001 | 08:27 PM
Vic's Avatar
Vic
purdy =)
Vic
Old Apr 7, 2001 | 09:37 PM
OgreDave's Avatar
Tight!
Old Apr 7, 2001 | 10:46 PM
Chunger's Avatar
WOOHOO! I'M STILL ALIVE!
I finally bled the brake system and cleaned up the mess of tools...
I took it out for a spin to heat cycle the pads/rotors... It's hard to get an impression so soon... but here goes...
While the car is stopped and the engine running... the pedal can almost go down to the floor... It was firm and stopped near the top when the brake booster wasn't helping.
While driving (I kept it under 40mph) it takes much less pressure on the pedal to stop... takes some getting use too... It wasn't great on the 1st stop but seemed to get progressively better (breaking in?) with each stop. I drove it around for about 20 minutes then came home. I'll cycle the brakes some more tomorrow... I did notice a little "squealing" when almost coming to a full stop (I didn't apply any "goop" to the back of the pads).
Old Apr 7, 2001 | 11:35 PM
Chunger's Avatar
WEIGHT COMPARISON part I
FYI
Old Apr 7, 2001 | 11:36 PM
Chunger's Avatar
WEIGHT COMPARISON part II
Old Apr 8, 2001 | 07:08 AM
NickStam's Avatar
Dope!
Old Apr 8, 2001 | 08:12 AM
Shingles's Avatar
The missing moderator
wow, 8lbs saving per wheel... talk about unsprung weight savings!
good job man!
thanks! BTW I saw one of the pictures that Dave posted, and my reactions was "wow that's big"
-Shing
Old Apr 8, 2001 | 09:58 AM
JonW's Avatar
Big Thanks!
Thanks alot for letting us in on the brake install, especially all of the great photos.
I agree that ~8 per front wheel is a lot of savings.
I haven't gotten my brakes yet, but I'm hoping that you're still planning on writing up a HOW2 before I have to do mine (being a Newbie).
Keep the insights on the "break in" coming.
Jon W.
Old Apr 8, 2001 | 12:31 PM
Chunger's Avatar
Re: Big Thanks!
Jon,
I will do a final writeup when I hear from Brian regarding the use of my "extra" washers to move the calipers out a bit...
Day 2: Not much of that mushy feeling in the pedal anymore... The pads/rotors have not completely settled in (The pads haven't scoured a good pattern on the rotors yet). The feel is more like what I had without my huge/heavy 18s... which is good.
NE1 know how the (2) factory rear proportioning valves work (the ones screwed on between the MC and rear brake lines? I'm wondering if we can open up the orifice in the valves to play with the rear bias (need the help of those of you who took fluid dynamics! hehe).
Jon W.
Old Apr 8, 2001 | 03:40 PM
clsund's Avatar
thanks for taking the plunge...
Chunger to figure out install process. We appreciate all you time and effort. Keep up the good work.
Old Apr 9, 2001 | 05:30 AM
OzziSVT
Damn, gotta get me some of those!
Dude, those brakes are SWEET!
Cuanto costa?
That set up look freaking huge. I love it!
It would even make a Ferrari owner envious!
Old Apr 9, 2001 | 09:27 AM
stjohnr's Avatar
Re: Re: Big Thanks!
Can you please try ur 16" rim tires. I am quite curious
on what clearances you have.
Thank you...
Jon,
Old Apr 9, 2001 | 09:37 AM
CoolMax's Avatar
is invisible
Hmmm...will they fit? I thought you needed at least 17" for clearance?
Old Apr 9, 2001 | 11:11 AM
OgreDave's Avatar
Nah, they should fit. 12.2 in 16's, 13 or so in 17's, 13.5 or so in 18's.
I got the 12.2's cuz i thought id be saving weight. lol, looks like it sure nuff.
Old Apr 9, 2001 | 11:31 AM
Chunger's Avatar
16" SE rims
I'll try to put one on maybe tomorrow... The weather is not that great... suppose to rain by the time I'm off work.
I have just over 1/2" (eyeballing it) with my Lowenharts...
Brian also proposed using shims between the hat and rotor (instead of at the calipers) so we can keep the extra 2mm on the calipers... We'll have to see if that will work...
Thank you...
Old Apr 21, 2001 | 07:17 PM
philpoe's Avatar
4 Maximas and counting
Hmmm, what do Stillen x-drilled weigh vs stock?
I just went back to verify... that 8lbs was over Stillen rotors... What do the stock ones weigh? Possibly more weight savings?
Any final tally of how many washers are needed? I gotta plan my trip to Home Depot Motorsports.
Was there ever a final write-up?
good job man!
-Shing
Old Apr 21, 2001 | 07:21 PM
Confused's Avatar
definitely more than a 3lb difference between
stock rotors and wilwoods!! the stockers are heavy.
I used 3/8" washers, 4 of them.
Old Apr 21, 2001 | 07:22 PM
Chunger's Avatar
Stillen cross drilled weight only 1/2 lb less than stock...
I'm trying to get the instructions/pics up by Wednesday...
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 17, 2016 04:54 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
