Need some help with fuel pressure gauge for my SC Max
I need to install my fuel pressure gauge but I have no idea where to tap my sender into. Can one of our generous members who have SC post a pic or email me? Your assistance will be grately appreciated. Thanx much in advance.
Here is the easy way to do it. There is no place to screw a sender in. Just cut the supply fuel line that goes to the fuel rail and T it in-line. Get a T-fitting, a couple hose fittings and hose clamps from a hardware store. I used washers to take up the gap of the ground wire on the bottom of the sender to the T to stabalize the terminal. You will need to get wire and the right size terminals to fit the top and bottom of your sender to wire it in. Wire from the base of the sender to a solid chassis ground. The other wire goes to your gauge.
![](https://maxima.org/forums/images/smilies/support.gif)
I hope you got an electrical one->
Anyway, I don't have a SC, but I tap it after the fuel filter and before the fuel rail. I bought a T fitting from a local performance shop. There are two hose fittings and one NPT fitting. I cut the fuel hose and put the T in between the two hoses. Screw in the sender in the NPT. Here's a picture. Sorry it's alittle blurry. The T fitting is made by Russel.
http://members.nbci.com/onemax2nv/Ma...r/DCP00157.JPG
Good luck.
Good luck.
aminus21
09-12-2015 04:53 PM
