Some troubles installing Catback..(pics)
Old Oct 18, 2004 | 06:54 AM
nupe500's Avatar
Jedi Knight
Ok...well I figured that it would be a pretty easy install as there are only 4 bolts to remove the OEM cat and install the new one. I spent pretty much most of the day finding a shop that had the correct gaskets for the max (they still aren't perfect-aftermarket BS)
Anyways..I get all the necessary stuff on Sat and decide that I'm gonna do the install on Sunday before football (or course)....well I've soaked the bolts for a bit and while they chill...I go to HD to pick up a torch figuring I may need to heat them bad boys up a bit. I was able to get one of the rear bolts off, but the other one wouldn't budge. SInce I was just gonna scrap the exhaust...all rusted...I decided to just cut the B-pipe and move on...well did so..
Once I got to the Cat...this is what I saw:
From the pics you can see that they bolts look welded or just melted together from all these years....so I had to drive around with no muffler...gonna go have a shop pull that thing off today..then install the Catback.
better yet, I may go rent a grinder and cut that bISH off!?!
Also what size bolt goes into the extra 02 bung?
Old Oct 18, 2004 | 07:30 AM
DanNY's Avatar
Ad·min·is·tra·tor
rookies!
i believe the stock cat uses studs...so it's not an actual bolt.
Old Oct 18, 2004 | 07:41 AM
nupe500's Avatar
Jedi Knight
Originally Posted by DanNY
rookies!
Hey veteran...it looks like that BISH is welded on there...still doesn't solve my issue/problem ....I outta...hey...PM me Dan...got some news for ya
Old Oct 18, 2004 | 02:00 PM
RA030726's Avatar
I'm nutty for Nissans
they are bolts, but they are really rusty. For mine I got the correct size socket on there and broke the head off. It makes the job so easy. the cat bolts will never come out unless you are good with a torch, or drill them out.
Old Oct 18, 2004 | 02:02 PM
SonicDust187's Avatar
What type of a bitt do I need to drill those things out?
Old Oct 18, 2004 | 02:31 PM
happyricefob's Avatar
V^___^V
18mmX1.5.....
Old Oct 18, 2004 | 02:33 PM
s0ber's Avatar
Mine came off with a impact gun
Old Oct 18, 2004 | 02:42 PM
gtr_rider's Avatar
192.168.1.1
I sprayed some Liquid wrench while the car was still warm, and let it do its work.. came off easily with a breaker bar.
Old Oct 18, 2004 | 03:16 PM
Pimpmobile's Avatar
When I had to replace my rear O2 it was stuck so I had to excise the cast bit after the cat. The bolts were so bad they didn’t even budge after I ground both heads off. Eventually I just got fed up and ground right through the flange and the bolts and replaced them.
Damn Canadian winters
Old Oct 18, 2004 | 03:59 PM
MaximaPolak's Avatar
I had a good torch to heat it up red in 5 sec..... That was fun.....and no broken bolts...
Old Oct 19, 2004 | 05:31 AM
nupe500's Avatar
Jedi Knight
Took the car to my boyz at CK Auto in South Philly...had that bad boy off in no time...had to use a plasma cutter to heat that bad boy up....then hammer on a smaller socket...and fffhwwwppp...them bad boys came off! Catback sounds so niCE and lovely...thanks for yer help fellers
Old Oct 19, 2004 | 08:09 AM
nupe500's Avatar
Jedi Knight
Originally Posted by happyricefob
18mmX1.5.....
is that 18mm the shaft or the head?
Slamrod
Apr 10, 2016 05:24 PM
neilraz
Sep 11, 2015 07:36 PM
95Maxi
35
Sep 2, 2015 10:37 AM
MikesChevelle
Aug 6, 2015 11:36 AM
