Wht does the MAP sensor do, and what are some
Originally posted by The New CLIMAX
causes of it going bad? Also does there need to be a vacuum line conected to it?
The computer only only reads the MAP sensor during the warm-up phase of the car. This is because the oxygen sensor would give the computer a false reading when it tries to determine if it should change the air/fuel mixture. The oxygen sensor would not work until it was warmed to operating temperature (similar to catalytic converters). When my MAP sensor would fail, the computer would put the car in limp-home mode (full rich). Once the engine was warmed up, I had no adverse affects from the failed MAP sensor. However, my engine oil would become saturated with gas and my spark plugs would get coated with carbon.
It appeared that the main culprit was a bad design (I tried high and low quantity replacement parts) and the location of the sensor in the engine compartment.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
