87 Maxima Shut of switch?
Old Oct 24, 2004 | 02:07 PM
SWFGirlgeek's Avatar
87 Maxima Shut Off switch?
Anyone know where the "fuel shut off switch" or "emergency shut off switch" is on an 87 Maxima? My car won't start after overheating and someone told me to try that. Thanx
Old Oct 24, 2004 | 04:08 PM
maximase86's Avatar
I love lamp.
Hmmmm, it won't crank over, or does it crank but just not fire up? How bad did the car overheat? I wouldn't be surprised if you blew out a head gasket if it had been overheating for a while.
S
Old Oct 24, 2004 | 04:33 PM
It cranks, just doesn't fire. Oil is clean, fuel to injectors from pump good. New plugs.
Old Oct 24, 2004 | 05:08 PM
acj's Avatar
acj
If fuel is getting to the injectors then the fuel cutoff switch hasn't been tripped and is not the problem. You need to find out why it isn't firing...or if it isn't just firing out of time, etc...
Old Oct 25, 2004 | 12:10 AM
max95q's Avatar
Check wires, distr. cap., rotor, timing like the guy before said. Also, was your car running before all this happened? If so what did you/it do afterwards.
Hondarydr
Dec 30, 2024 06:15 PM
fastcarny
May 18, 2020 10:40 AM
98nismomax
Aug 13, 2015 12:15 PM
erniel
Aug 8, 2015 09:32 AM
kjm900r
Aug 5, 2015 07:14 AM
