Oil temp gauge.
Old Oct 24, 2004 | 07:31 PM
MaxSpeedSE's Avatar
Oil temp gauge.
I was wondering what is required to hook up an oil temp Autometer gauge up to the Maxima? Does the gauge it self come with everything you need?
-Chris
Old Oct 26, 2004 | 01:58 PM
erty67's Avatar
Decal Specialist
I'm going to assume the oil temp gauge comes with the same stuff as a tranny temp gauge. I did a tranny temp gauge in my car and it came with the wiring, gauge, and sending unit. I had to have a hole drilled into my tranny pan to tap in the sending unit though. I think some guys on here have split off a oil line to tap in their sending units for oil temp. Don't know if this helps, but i thought it might.
Old Oct 27, 2004 | 08:38 AM
1MAX2NV's Avatar
The correct way would be to drop the oil pan. Weld on a bung. Screw the sender into the bung. If you can't weld, you can just take the pan to a muffler shop.
Old Oct 27, 2004 | 09:00 AM
Zack342's Avatar
or you can get something like this which will be cheaper in the long run, no need to take off oil pan or have it modifided
you welcome
http://www.importparts.com/shop/prod...oducts_id=1642
Old Oct 27, 2004 | 04:19 PM
Maximus_95's Avatar
i have an oil pressure gauge. is that the samething??? i just put it on this past weekend, did the power and ground, but did not know where the other 2 wires should go to.
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
05RLS2
Apr 14, 2016 11:49 AM
