VQ40 in a Max
Old Oct 31, 2004 | 03:07 PM
Wish-it-was-AWD's Avatar
VQ40 in a Max
so, what about it...longer stroke, anyone else know any details?...get a discussion going...brainstorn....VQ40dett?.....in a max?
Old Oct 31, 2004 | 03:10 PM
BTW it's the new VQ in the new pathfinder...270hp, 290 torque good start..
Old Oct 31, 2004 | 03:14 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
block height is supposedly different but I may just try it once i can get a hold of one. BTW probably wont clear the hood.
Old Oct 31, 2004 | 03:24 PM
sagamax's Avatar
Give me a Bud Light Holmes
interesting
DAVE Sz's Avatar
Hooooooonda.....
This discussion was started months ago I believe.
Old Oct 31, 2004 | 03:25 PM
screw the hood, cut it muscle car style or build cf or fibr gls....use L/C slugs and bolt a GT 3540 and A fmic, Quafe it, stand alone FMU, ....Dir Port N20.....nasty...
Old Oct 31, 2004 | 03:26 PM
so....any results of the brainstorming?
Old Oct 31, 2004 | 03:29 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
maybe in '06 or '07 we'll see a VQ40 in a Max
Old Oct 31, 2004 | 03:31 PM
TILLEYS99's Avatar
Stroke will probaby be poor for high rpm.
Old Oct 31, 2004 | 03:41 PM
light slugs though?
if I'm not mistaken, the 3.5 slugs are the lightest production on the market, same as in the VQ40 I would assume so hopefully with some knife edging of the crank and some tighter springs and retainers, you could spin to 7.5k safely, boosted with the stand alone ECU and a seriously ported 3.5 head, or at least the cams, and sodium filled stainless oversized valves....maybe we'll see this conversion done in the R35 skyline if it goes to the VQ35DETT set-up....
Old Oct 31, 2004 | 03:44 PM
TILLEYS99's Avatar
just do a 3.5 like i did i gained so much lowend torque.
Old Oct 31, 2004 | 03:48 PM
difficulty rating, cost, clearance problems....6-spd possible? deatail always appreciated...thx
Old Oct 31, 2004 | 03:50 PM
good point...we can hope
maybe they'll even design it for more high end and crack the 300 hp and toque threshold...
Old Oct 31, 2004 | 04:23 PM
TILLEYS99's Avatar
http://forums.maxima.org/showthread.php?t=328597
Old Oct 31, 2004 | 04:32 PM
SR20DEN's Avatar
VQ Wizard
I was all about wanting to do this swap untill I got more details of it.
http://www.poweredbynissan.com/Engin...ngineSpecs.htm
The VQ40 is a taller block and won't easily fit in the Maxima anyways.
Old Oct 31, 2004 | 08:09 PM
http://nissanperformancemag.com/june04/aebs/
Old Oct 31, 2004 | 08:19 PM
SR20DEN's Avatar
VQ Wizard
I wish we could ban any future references to that thing.
@ $7800 NO Maxima owner would ever buy it.
Old Oct 31, 2004 | 08:22 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
reminds me of the $9000 VG motor that can be purchased
Old Oct 31, 2004 | 09:03 PM
tedo007's Avatar
faster than you think
wow 40dett
Old Nov 1, 2004 | 05:40 AM
Tatanko's Avatar
Bacon Lover
Exactly, there's no point in spending that much just to have a larger Maxima engine...put that sort of thing to better use on a Z/G35.
I don't think a VQ40 in a Maxima is possible or truly worth it, for a lot of reasons. For one, it obviously won't clear the hood and I think it'll be by more than just an inch or two. I think it would look incredibly stupid to be driving around in a "sporty sedan" with something big sticking out of your hood. I already hate hoods on Maxima's with any kind of bulge or scoop to them. Secondly, the raised displacement is entirely in the stroke, and as someone has already mentioned, that large of an increase in stroke is going to hurt revving capabilities.
But...at the same time, the stroke is still smaller than the bore. If the stroke were a lot more than the bore it would be one thing, but it's still smaller. So who knows how well it's going to operate. Surely Nissan wouldn't use it if it were terribly bad.
Old Nov 1, 2004 | 10:23 AM
thanks for the link
thanks for the link and details
Old Nov 1, 2004 | 10:48 AM
exactly....
Originally Posted by tedo007
wow 40dett
let's make it happen....start looking for specs on the VQ40's deck height, internals, etc..
Old Nov 1, 2004 | 06:15 PM
I'm amazed, b/c when the 1st VQ35DE came out about 3 or 4 years ago, it was used exclusively for Pathfinder. Look how widespread the VQ35 has become since its debut. About my post stating there could be a VQ40 in a future Max and after reading everyone else's view, the VQ35DE in the '06 or '07 Max somehow will get a huge power boost and retain its 3.5L design or it will be stroked to a VQ38DE
but this is years from now, though
Old Nov 1, 2004 | 07:03 PM
SR20DEN's Avatar
VQ Wizard
Deck Height: The distance from the top of the piston to the top of the block deck.
Block Height: The distance from the crankshaft centerline to the top of the block deck. <~~ This is the only one we're concerned with because Nissan engines typically have a Zero deck height.
I search for this data a few times a week and was actually the first to provide the bore & stroke info. Once Nissan finally releases the Service manuals I will post more of the data. But right now there simply isn't anything else publicly known about it.
Old Nov 1, 2004 | 08:14 PM
thanks
I was thinking, VQ40DE (possibly lowering motor mounts) knife edging crank with '04 6-spd, TB from VK56DE (if compatibleVQ35 ported and match honed heads, with aftermarket cams, (ground for mid-range tohigh rpm power), new springs and retainers, MEVI or VI from gen 5 or 5.5, Quaifed diff, and maybe a bolt on S/C or turbo manifold with an upgraded Garret GT3540, 4" custom cat back, and a stand alone to deal with ECU compatibility...hood will be easy to modify if necessary....would look really nice with custom wide-body kit holding some 275/35ZR18 Volk GT7s....or if the stand alone is too expensive and you're going all-motor, you could just get a reflashed JWT ECU, to allow it to spin to 7500 or higher...with tuning, trial and error, I'm thinking 335 crank HP all motor is possible with over torque easily over 300..550 plus blown....600 plus with a huffer and some giggle gas....just hoping....may try and do it myself...just trying to work out the feasiblity...thanks again for the input
Old Nov 1, 2004 | 08:46 PM
dadonfromqueenz's Avatar
wow, i wanna talk just like u guys one day....
one day....
Old Nov 1, 2004 | 08:50 PM
one day....
you either have a great sense of humor...paid us a great compliment, or are a total...hopefully it was one of the former
Old Nov 1, 2004 | 09:06 PM
krismax's Avatar
Father of the 00 VI
This would be a huge waste of money a 350z with rods pistons and valvetrain work with the 3.5 with a twin turbo kit .
It runs 8.3 @ 176 in the 1/4 with street tires and with the stock open deck has 1000+ rwhp .
If you were looking for it built for na id say good but for speed the 3.5 with a few thousand in work will be stronger than a sh$t brick house.
Old Nov 1, 2004 | 09:18 PM
but can yo0u fit a VQ35DETT in a max?
that's why, plus it's original....VQ40DET or VQ40DES is unheard of, especially in a FWD 4th Gen max...but good point....so let's do it in a G35...I mean G20
Old Nov 4, 2004 | 06:37 AM
so...
Anyone found any more definitive info about the engine, aside from output and the models in which it will be offered...?
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
