people w/ place racing CAI
Old Apr 15, 2001 | 06:46 PM
1HOTMAX's Avatar
how do u know when your filter fell off cause it is mounted on upsided down. i made sure that it was mad tight but hey, the roads are bumpy and shiet happens........
Old Apr 15, 2001 | 06:58 PM
Sprint's Avatar
In my case i looked behind the fog light housing.. but i dont have fog lights..
for you .. bump the bottom of the thing and see if the filter fell down or not... and it would be considerable louder..
i had that fear for about 1 week if the filter fell off or not.. and if i was running un filtered air what would happen..
Old Apr 15, 2001 | 07:35 PM
BIGMAX's Avatar
I cut out the plastic fender lining under the filter for better air flow.
My filter hasn't fell off yet.
If it does fall off there will probably be an unexpected thump as my tire runs over it.
Old Apr 15, 2001 | 07:55 PM
Sprint's Avatar
you are going to have to clean it twice as often as you should because that plastic fender lining was there to keep most of the dirt out... and snow and rain if you live in those regions
Confused's Avatar
Permanent Maxima.org Resident
i told ya
pull the clear bumper lens
Old Apr 15, 2001 | 08:09 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
hope u live in a dry, non dirty area....
1HOTMAX...if it's tight you shouldn't have a problem...it will be very loud w/o the filter
Old Apr 15, 2001 | 08:59 PM
BIGMAX's Avatar
I live in Florida. Usually a lot of rain. But we're in a drought right now.
I clean it about every 10K or so.
Water is no problem, I've driven in a down pour with no lining on what so ever. Intake fully exposed and had no problem.
Old Apr 16, 2001 | 03:47 AM
Ramius83
I solved this problem by atucally bolting the filter to the metal of my car. It was pretty easy. When I get my camera back, I will take some photos for you all. All I did was install some "headless" bolts into the filer, drilled holes in the car, pushed the filter (and black piece) up through those holes and used locking nuts to secure it. Very nice set-up. Easy to do as well.
Old Apr 16, 2001 | 04:49 AM
nodoubt711's Avatar
same thing as bigmax, if it falls off, i will run over it
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
TKHanson
Nov 24, 2018 01:39 AM
Sep 27, 2015 08:37 AM
