knock sensor help
Old Nov 22, 2004 | 07:43 AM
furbiss112's Avatar
knock sensor help
well, what i need to kow is if anyone has replaced theirs without removing the intake manifolds. if so will it long? also how damaging to the engine is a bad knock sensor. is it ok to drive with it for now or not. thanks in advance.
Old Nov 22, 2004 | 08:43 AM
NmexMAX's Avatar
dot dot dot ...
You've been here long enough to know the answers to those questions. Do me a favor and search and read the stickies/FAQ's.
In short it's very possible to do w/o removing the IM, and took me 15 mintutes, I was lucky, and it is ok to drive w/ a bad sensor, as the timing is pulled back (retarded) and will not cause any damage other than bad gas mileage and poor performance.
Old Nov 22, 2004 | 08:52 AM
Gen8888's Avatar
Yes it is very easy to do without taking off the IM. I just did it 2 days ago. All you need is 12mm Swivel, ratchet, and an extension. Takes about 10-15min to do the job. Also find someone that has small enough hands to fit in there or your hands if small enough. I couldn't even get half of my hand in there. If you wanted, you could use wd-40 or pb and soak the bolt beforehand as well.
Old Nov 22, 2004 | 11:04 AM
Ms.Maxima™'s Avatar
You don't need small hands to do it. As a matter of fact, you don't need to stick your hand down there at all if you know how to do it right.
Old Nov 22, 2004 | 11:14 AM
MrRogerStatus's Avatar
VQ Disciple
ERRRR are we still talking ablout Knock sensor
j/k
anyways read the sticks dude.
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
