Change Cali spec to Fed spec?
Old Apr 20, 2001 | 01:12 PM
ajaffee
Just curious. Is this possible. Would removing the extra emmisions sensors on California spec vehicles cause known or unknown problems?
Old Apr 20, 2001 | 02:06 PM
Daniel B. Martin's Avatar
What makes you think there are "extra" sensors on the CA cars?
Old Apr 20, 2001 | 02:13 PM
ajaffee
I saw this link in a previous post. It could certainly be wrong.
http://www.cattman.com/images/produ...pec-diagram.jpg
Old Apr 20, 2001 | 02:49 PM
404 File Not Found
I clicked on the URL you provided and got the dreaded 404 File Not Found.
Old Apr 20, 2001 | 02:59 PM
Green 2kSE's Avatar
Try this link.
Old Apr 20, 2001 | 03:28 PM
Pmp-n8a's Avatar
removed 1 and 2....took it out for a drive and nothing happens..
Old Apr 21, 2001 | 07:13 AM
California spec cars
Originally posted by Green 2kSE
Try this link.
Thank your for the link. The following information is based on the '99 Maxima factory service manual.
The four numbered items are electrical connectors, not sensors. However some lead to sensors.
Item #1 is connector F48, Rear heated Oxygen Sensor LH (for California)
Item #2 is connector F28, Front heated Oxygen Sensor LH
Item #3 is connector F27, an intermediate connector (for California)
Item #4 is connector F49, Rear heated Oxygen Sensor RH (for California)
The FSM doesn't provide a lot of detail about the differences between CA and Fed specs. The connector designations, above, suggest that CA spec cars have two rear Oxygen Sensors, while the Fed spec cars have only one.
Perhaps our Maxima.Org members in California can clarify this.
Old Apr 21, 2001 | 07:18 AM
spyder
lolol if someone from cali can actually, and correctly diagnose this ill eat my fries with green ketchup.
Maybe someone from cali can answer this... dunno definetly not that clown kev
Old Apr 21, 2001 | 02:36 PM
Pmp-n8a's Avatar
so basically if i wanted to rid myself of a check engine light while changing my car from cali to fed spec all i would have to do is removie 1 3 and 4 and the corresponding O2 sensors would be inactive?(I wouldnt get a check engine light)
Old Apr 21, 2001 | 02:51 PM
I couldn't say. The Factory Service Manual doesn't give enough information on the subject. I doubt it is as simple as disconnecting the sensors, but you could give it a try.
Old Apr 21, 2001 | 03:13 PM
UMD_MaxSE's Avatar
Got Bent?
From the 5th gen perspective
The Cali spec emission maximas have three 02 sensors. The main difference between Cali and Fed spec is that Cali spec maximas have two pre-cats with one being built into the front exhaust manifold. Two sensors are placed past each of these two pre-cats and the last sensor is placed after the main cat. There has been some speculation and experimentation by Desert Pearl on the 5th gen forum to convert his exhaust to Fed spec. He has gotten hold of a fed spec exhaust manifold that does not have the pre-cat. He has moved the two front O2 sensors back to behind the main cat to see if he can fool the ECU into thinking that the pre cats are still there. The only time this may trigger a check engine light is when the car is cold since it takes some time for the main cat to heat up. Hopefully he will post an update to his work soon.
Old Apr 21, 2001 | 04:23 PM
Pmp-n8a's Avatar
if these prongs are the connectors for the O2 sensors...why doesnt he just remove these and cut the O2 sensors from the exhaust completely?(if possible)
Old Apr 21, 2001 | 04:28 PM
UMD_MaxSE's Avatar
Got Bent?
cutting the sensors off will almost definitely trigger a check engine light. If the ECU doesn't see them it will freak out and may put the engine in limp mode.
Old Apr 21, 2001 | 05:54 PM
y2kse's Avatar
Re: From the 5th gen perspective
There seems to be a lot of confusion about this. For the record, CA-spec 5th Gen Maximas have FOUR (4) O2 sensors, one before and one after each of the two pre-cats. NONE of the O2 sensors are mounted aft of the main catalytic converter on CA-spec Maximas. I've got the exhaust diagram from the FSM to prove it.
Desert Pearl has moved the rear O2 sensor from each pre-cat to a position behind the main cat. For those who need help with math, that means he now has TWO (2) O2 sensors mounted behind the main cat. He'll mount the front O2 sensor from the left (front) pre-cat into the left (front) downpipe and the front O2 sensor from the right (rear) pre-cat into the right (rear) downpipe of a Stillen Y-pipe. Then we'll see if that generates a Check Engine Light.
Old Apr 21, 2001 | 05:59 PM
UMD_MaxSE's Avatar
Got Bent?
Re: Re: From the 5th gen perspective
my bad....thanks for the correction
Old Apr 21, 2001 | 06:13 PM
y2kse's Avatar
Re: Re: Re: From the 5th gen perspective
No worries, UMD_MaxSE.
The Wizard
24
Oct 1, 2015 08:47 PM
QueensMAX
Sep 15, 2015 04:14 AM
16_SR
Sep 9, 2015 07:14 PM
Samedi
Sep 3, 2015 01:07 PM
