G-teck vs. track tonight>>>
Old Apr 20, 2001 | 07:52 PM
98MAX's Avatar
It was off by .3 and 3mph over(because its your true speed).
Here are the times. I used the NOS from 2nd gear on only so I would not spin outin first gear, cause the track sucked tonight.
14.57@94.68 G-teck 14.89@97 0-60 6.33
14.51@94.93 G-teck 14.80@97 0-60 6.25
14.56@95.92 g-teck 14.84@97 0-60 6.30
Not off by much.
Old Apr 20, 2001 | 08:25 PM
Nismo87SE's Avatar
Actually your trapspeed is your speed at the end of the 1/4. Its no different if you were to measure it with 60ft or 5ft traps. I believe from what you posted that the Gtech times were 3 tenths higher. Usually Gtech reads 1-3 tenths lower and 3-6mph higher. Now you know that your car does 0-60 in the 6.0-6.2 range, not bad .
Old Apr 20, 2001 | 09:42 PM
theblue's Avatar
Not off by much.
how much NOS, and what other performance mods?
Old Apr 20, 2001 | 11:00 PM
Loren00Miata's Avatar
This matches some of my own testing with the G-tech. I used the G-tech on the same road in 3 different cars. The greater amount of lift and dive in a car, the more accurate it seems to read. It tripped the end of a 1/4 mile 200 ft later in my Saleen than in my CRX. The bottom line is that is doesn't work for trying to get accurate numbers, but it will give a realistic indication of the change that different modifications will make on a vehicle if it tested each time in the same conditions.
Old Apr 20, 2001 | 11:13 PM
Synki's Avatar
Yeah, just curious what you have. Are you auto?
Old Apr 21, 2001 | 06:48 AM
98MAX's Avatar
I have a 97 auto with moddified intake and Stillen y-pipe with catback and rt cat. I run a 40"shot" dry kit from NOS. I don not usaully hit the nos till top of first gear or even second. My best time is 14.09@96 on my 17s but I have ran 14.3@98 on some ****ty 15s. So with a NOS controller and some BFG's I will be in the 13s.
Old Apr 21, 2001 | 07:40 AM
theblue's Avatar
That's impressive, mostly because its an auto. What at your 60' times and what is the best time you have run without NOS (if you know)?
Old Apr 21, 2001 | 08:07 AM
got rice?'s Avatar
I thought they measure the MPH at two points, at the 1320' mark and another location before that and average it out. It's not the actual trap speed when you cross the line.
Old Apr 21, 2001 | 10:43 AM
98MAX's Avatar
My best time with no NOS is 15.2@90(not on 17s). My 60' is usually 2.08-2.15 range. I had 2.3s posted cause I was not using the NOS till second so I could test the g-teck. I run 9.0@78 in the 1/8 and can pull about 98mph in the 1/4 depening on traction.
Old Apr 21, 2001 | 11:52 AM
Francis96se's Avatar
yes as far as i know the trap speed is actually an average at the end...not your true speed as you cross the 1/4 mile mark.
mkaresh
Mar 12, 2018 06:48 PM
jonreidhead
Jan 6, 2016 09:38 AM
