Performanceix has Maxima How-2's
Old Apr 23, 2001 | 08:35 AM
NickStam's Avatar
www.performanceix.com has a couple of Nissan Maxima How-2's.
Under Electronics/Audio is "Speaker Removal"
Under Suspension is Koni install and Sprint Springs
Old Apr 23, 2001 | 01:56 PM
_DRU_'s Avatar
nice links, i was waiting for the spring install and the pics are nice and instructions seem pretty easy. i have a question though.. im only swapping the springs so what is there anything i can leave out? thanks for the link though, very informative.
Old Apr 23, 2001 | 02:27 PM
NickStam's Avatar
If you are just swapping springs then you would just need steps 1-9.
Old Apr 23, 2001 | 02:44 PM
_DRU_'s Avatar
thanks, they are the exact same steps for the rear too right?
Old Apr 23, 2001 | 03:22 PM
NickStam's Avatar
The rears are even easier. One bolt on the bottom and two bolts inside the trunk. I didn't have a digital camera when I did the rears so I need to develop them before doing the write-up.
Old May 4, 2001 | 07:47 AM
NISMO808's Avatar
Hey nick, I just did the koni/sprint rear install last night. I had a question about the height. When you installed your koni's where did u place the little ring that holds up the strut base. There were two grooves. When I got the koni's the ring was on the second groove closest to the bottom, however I moved it up to the top groove cause the strut wouldn't reassemble. Was i supposed to leave the ring on the first groove and cut the rubber bump stop?
The reason why i ask is cause I don't think the back was lowered that much compared to stock. My car looks like a dragster. Any insight would be appreciated. Thanks.
Al.
Old May 4, 2001 | 08:06 AM
Sprint's Avatar
i think thats the sprint springs.. when i did mine i looked at the car and thought.. wait a second.. the rear didn't move.. but it did just a little.. the front looks lower than the rear
Al.
Old May 4, 2001 | 08:25 AM
NISMO808's Avatar
Do you have pics of ur rear fender gap?
Old May 4, 2001 | 08:51 AM
NickStam's Avatar
What do you mean that it wouldn't re-assumble. I left mine on the lower setting (how it came in the box) because I knew that the Sprint springs would make it look slighly higher in the rear. Here are some pics of my car:
http://www.performanceix.com/maxima/gallery01.asp
Old May 4, 2001 | 11:11 AM
NISMO808's Avatar
when on the lower setting the springs would sit lower from the top. Thus the Upper strut seat would not rest ontop of the springs. There was a lot of space. Leaving me to believe that I had to cut the bumpstop or something However I wasn't quite sure and I didn't want to risk it. Did you have to cut anythign for the rear?
This was the order of stuff that I assembled the strut.
bolt
washer
upper strut seat
round black rubber thing
rubber bumpstop attached to sleeve
springs
strut base (on the upper setting)
In this setup the upper strut seat fit on top of the springs directly and all i had to do was compress a lil and tighten the top bolt.
In the other setup the strut seat did not touch the springs.
Old May 4, 2001 | 12:19 PM
NickStam's Avatar
I cut one notch out of the rear bumpstop.
halfpol
Oct 17, 2022 12:16 PM
Goffery2uned
Aug 21, 2015 09:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
