Fastbrake Wilwood Instructions
Old Apr 25, 2001 | 04:13 AM
Chunger's Avatar
My other car is a Hybrid
I've still got to revise this but...
TENTATIVE INSTRUCTIONS
Let me know what you think...
Old Apr 25, 2001 | 04:33 AM
DNA21's Avatar
Excellent! The instructions are through and the pics help immensely.
I can’t wait for the next group buy on the brake kit!
Old Apr 25, 2001 | 04:41 AM
Confused's Avatar
Permanent Maxima.org Resident
Looks good
I used just two 3/8 washers for the centering... but then again, yours fit Did Brian recommend a break in procedure?
Old Apr 25, 2001 | 09:55 AM
Chunger's Avatar
Re: Looks good
I believe he said take it easy for about 150 miles...
I feel the actually break in is much longer... I still don't think my pads have completely settled in...
I did try some hard stops.... I had a big afterwards.
What are your impressions so far Brett? or NE1 else who has done it... pics on SE rims would be nice too!
Old Apr 25, 2001 | 05:25 PM
Confused's Avatar
impressions?
i'll tell you friday night after round 2.
Old Apr 25, 2001 | 05:26 PM
Loren00Miata's Avatar
I used to have a set of Brian Hasty's 'Fastbrakes' on my CRX. In fact, it was one of the first sets he made. He supplied the adapters and you get a set of 90+ Integra calipers and 11.0" VW Corrado rotors. Other than having to mill the brake caliper bracket some for bolt clearance, it was a direct bolt-on. There were no washers needed for relocation. The CNC machined aluminum caliper relocating brackets were a nicely designed part and fit perfectly. If you go to Brian to have some made for the Maxima, I am sure he will do an excellent quality job.
Old Apr 27, 2001 | 12:41 PM
JonW's Avatar
Is the link to the instructions dead or is it just me?
I still haven't had the opportunity to install my new brakes yet. I keep getting distracted by other things. Hopefully, I'll be able to use Chunger's instructsions when the time comes.
Chunger, you mentioned using shims instead of washers to center the calipers. Pardon my ignorance, but where could I get the shims that I need?
Thanks again for forging ahead.
Old Apr 27, 2001 | 02:05 PM
monty365's Avatar
Torque technique?
Thanks for doing such detailed instructions for the installation. You make me want to learn enough to work on my own brakes.
Being a newbie, I have a question. Toward the end of the installation it says:
REINSTALL THE NEW CALIPER AND TORQUE THE 7/16” BOLTS TO 50 lb-ft PER INSTRUCTIONS. (YOU WILL NEED A 7/16” OPEN END WRENCH FOR THE TIGHT FIT!) SEE BELOW STEP.
It appears from the pictures that the 7/16" bolts have an allen head on one end. How does one apply 50 ft-lb of torque? Please tell me how to do this. I did not notice any allen adapters on the shelves at Sears when I got my torque wrench to install my fstb and rsb. If this is a common tool please excuse my newbie ignorance and tell me where I might find the adapters.
Thanks for the post and the assistance.
Old Apr 27, 2001 | 02:16 PM
Chunger's Avatar
The host site is sometimes flakey... keep trying.. I'll try to relocate later... I'm still working on the page.
Shim in this case is washer... sorry...
Old Apr 27, 2001 | 02:34 PM
Chunger's Avatar
BTW.. I think I found a machine shop that is willing to do the crossdrilling...
I guess I'll be the guinea pig again...LOL
Matt93SE
May 24, 2019 02:58 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
