Test & Tune smiled on me tonight...
Old Apr 26, 2001 | 09:32 PM
bullseye's Avatar
My times continue to work their way down. Tonight, with a warm track and cool ambient air, I achieved a new personal best in the 1/4: (I guess I need to update my sig now...)
r/t: .516
60': 2.123
330: 6.113
1/8: 9.436
1/4: 14.697
MPH: 93.12
On this particular run, I ran against a Rustang 5.0, waxing his a$$ by over 1/2 of a second. FYI, my time was "clutch-limited", as my clutch didn't want to clamp down with vigor on my 1-to-2 shift. That dang clutch did this to me TWICE tonight. I guess it's time to install a beefier clutch and a lightened flywheel. And I'm not on bottle-assist yet... Ooh baby!
Old Apr 27, 2001 | 04:13 AM
Pervis Anathema's Avatar
Must be nice... My '91 would be lucky to run a 41.697...
Old Apr 27, 2001 | 05:54 AM
maxfreak_98's Avatar
Those are some awesome 60' times. What's your secret to get a launch like that? Were you using your drag radials?
Old Apr 27, 2001 | 06:12 AM
BEJAY1's Avatar
Conecarver
Yes please tell us how you launch - w or w/o drag tires!
Old Apr 27, 2001 | 07:38 AM
Dave B's Avatar
Not DAVEB the parts guy
Wow, yummy 60'. Let me know how you did it. Did you run BFG DRs or street tires? What's your "track setup".
Everyone else:
What's your honest opinion of the UDP. Good, bad, decent?
Dave
Old Apr 27, 2001 | 06:42 PM
bullseye's Avatar
Check my sig... When I race, I mount my stock 15x6.5 alloy rims on the front, shod with 205/50/15 BFG Drag Radials. I have driven around town with these on the car to wear some of the tread off. In fact, there isn't much tread left on them now. I *inflate the back* tires to 44-psi to minimize rolling resistance. I *deflate the front* tires to 20-psi to optimize grip at the start.
The 15" rims afford some side-benefits:
- They are lighter than my everyday O-Z rims.
- They give my car a nose-down attitude, lowering the front about 1" lower than the back. This helps reduce the normal weight transfer to the rear at launch.
- This wheel/tire combo has a smaller circumference than my everyday wheels/tires.
With my everyday 16" Monte Carlo wheels, a shift into 4th gear near the end of the track is not really practical. I just don't get more speed with that. I am forced to scream across the finish line in 3rd gear. WEEEEEEEEEEEEEEEEEEEE!
When I switched to my 15" wheels and low-profile DRs, I found I could shift into 4th gear sooner before the finish, into a meatier part of the powerband. I believe my 3rd to 4th gear upshift helps me run faster now. In fact, I think the switch to 15" wheels and DRs helped me pick up 2/10s.
When I approach the starting box, I by-pass the water. I do a *brief* dry spin to rid the tires of debris. I stage thin at the staging lights to get a running start, and I rev my engine to about 2,000 rpms. I immediately focus on the lights, because our track starter has an itchy trigger finger! (Ya gotta get ready to GO!)
I launch *just* before the 3rd light. I very quickly ease out on the clutch as I very quickly add in throttle. It is as close to dropping the clutch as I can get without really dropping the clutch, if you know what I mean. I follow the launch with a hard PUNCH to WOT, running the rpm needle all the way to redline in 1st before I shift into 2nd. I do a QUICK lift-throttle shift at every gear. Whenever I power shift, the dang clutch slips a little, robbing me of time. I shift as fast and smooth as I can, and my shift from 3rd to 4th is a blur. BAM! I haven't missed a gear yet...
I learn new things everytime I go to the track. Practice, practice, practice. Set goals. Evaluate/Chart progress. When you can ****** this pebble from my hand, it will be time for you to go, Grasshopper! Good luck.
Old Apr 27, 2001 | 09:20 PM
Dave B's Avatar
This is my technique:
-quick 1/2 second spin to clean the tires
-set the prestage light
-creep up just until the stage light is set (shallow stage)
-rev up to 3000
-on the 2nd amber I quickly slip the clutch and feed gas and hope I land at 3000.
-take 1st to 6500, 2nd to 6300, 3rd to 6000, hold on to 4th
This usually nets 14.7-14.8@93+mph. My 60 foots are always in the 2.25-2.30 range. I usually get a bit of spin and hop on the launch. I'd slip the clutch more, but I don't want to burn it out. I usually drop the fronts down to 26 psi and bring the rears up to 42psi. All runs on my 16" K1s with 215/55 Yokohama all-seasons. I plan on drag radials in the near future. I hope the slight torque multiplication of the shorter tire (stock 15" wheels) and the grip might push me into the 14.4-14.5 range on a cool night.
How do you like that UDP? Did you notice anything (butt-dyno, track results)?
Thanks,
Dave
Old Apr 27, 2001 | 10:29 PM
theblue's Avatar
doh! I forgot to raise my back tire pressure on my best run... is a 14.7 possible? I run at 22 on the front... here is what I did on my 2.213 launch (on lame toyo tires)
- stage neutral...
- on first yellow rev and hold at 3000
- pop clutch on third yellow
- release gas a little to get traction.
- gun it for all I can
- shift at 6200 into 2nd
- shift around 6000 for the rest of the gears...
got me a 14.8
Old Apr 28, 2001 | 05:27 AM
bullseye's Avatar
-rev up to 3000
Thanks,
Dave
The UR UDP is a jewel. (I got a black one for stealth.) I believe the exhaust mods I have rob me of a little low-end torque. I also believe the UDP gets it back. The engine seems to rev more quickly, too. A lightened flywheel will accentuate this feeling, I'm sure.
On my last visit to the track, I made 5 runs. I had no wheel spin, nor wheel hop, on any of those runs...
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
Socalstillen
Sep 26, 2015 12:01 PM
