Possibility of 4.0 maxima?
Old Jan 26, 2005 | 05:47 PM
NJ Devils Fan's Avatar
Not sure if it was talked about, but what are the odds of use seeing a 4.0 maxima in the near future. I saw that the new pathfinders have 4.0 liter engines.
Old Jan 26, 2005 | 05:51 PM
Ant96GLE's Avatar
Its been talked about... eventually it will happen once the 3.5 gets out dated... and most likely it will end up in the G as well...
Old Jan 26, 2005 | 06:01 PM
konak85's Avatar
I mean how large can it get in the future? VQ65?
Old Jan 26, 2005 | 06:18 PM
MacAlert's Avatar
Uhh, you can get a 4.0 in your 5.5 max now.
Ant96GLE's Avatar
Theres no replacement for displacement
Old Jan 26, 2005 | 06:28 PM
konak85's Avatar
TECHNOLOGY
Old Jan 26, 2005 | 06:30 PM
Ant96GLE's Avatar
Originally Posted by konak85
TECHNOLOGY
Keep thinking that... if the Max was RWD with a 5.6 liter Nissan V8 you sure as hell wouldnt be saying that.
Old Jan 26, 2005 | 06:32 PM
konak85's Avatar
Your damn right.
Old Jan 26, 2005 | 06:34 PM
Turk's Avatar
I want a maxima that RWD with a turbo... How sick would that be and not to mention 2 door.
Old Jan 26, 2005 | 06:36 PM
SR20DEN's Avatar
VQ Wizard
Pretty much 4.0-4.5 liters is as far as it will ever go. The VQ40DE isn't even the same block and almost could have been called something else.
Old Jan 26, 2005 | 06:37 PM
konak85's Avatar
A RWD Maxima without turbo would even be sick. Damn Nissan.
Old Jan 26, 2005 | 06:43 PM
theMax's Avatar
There is a 4.3L rebuild kit for the VQ for about 10K.
Old Jan 26, 2005 | 06:53 PM
NoMotive's Avatar
RWD? Yeeeeah and i'm the magical man from happy land, with a gumdrop house on lollipop lane! Keep on dreaming.
Old Jan 26, 2005 | 07:40 PM
Frank Fontaine's Avatar
My hunch is that with Nissans being hard enough to move off the lots (here we go again, Titan out in the 2nd year, REBATES. Altima, REBATES. Maxima, REBATES. Shift_Resale? No, S**T resale. Actually, there are 2, yes two, Nissan models that don't have a rebate right now, and that is the Murano and 350Z. Can you believe the brand-new Pathfinder qualifies for a $500 college rebate? And the Mexican Sentra, $2000 rebate. Yes Virginia, Nissan's lists are artificially inflated. They are designed to be sold with rebates. Too bad for anyone who buys one without, because they can subtract the rebate right out of their trade-in value after 1 year.) What would be the purpose of a 4 liter? More hp, more expensive, harder to sell, and still FWD. I'd make a gentleman's wager the car gets discontinued before the motor gets larger.
Putting the Pathfinder motor in the Maxima = 5 more HP, 36 more ft.-lbs. torque, and worse emissions. No way. Odds are about as good as the Pats winning the Super Bowl! Or the Devils winning another Cup.
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
only time will tell .. kinda too early to tell whether the max will get the VQ40
Old Jan 26, 2005 | 07:55 PM
SR20DEN's Avatar
VQ Wizard
Only it isnt a rebuild kit and it isn't 4.3 liters.
It requires VERY extensive machine work and there are two sizes to choose from. One is 4.2 liters and the other is 4.4 liters.
Old Jan 26, 2005 | 08:01 PM
SR20DEN's Avatar
VQ Wizard
Your entire post is meaningless. Go educate yourself with some meaningful info. www.nissannews.com . Someday you might understand that Nissan Motor Company now has among the very highest profit margins for auto manufacturers. And their sales growth percentage was higher than ANY other manufacturer in the US last year.
This has already been done once. The Maxima just got a more powerful version of the VQ35 than the Pathfinder.
Only Honda Motor Company had a cleaner vehicle lineup than Nissan in the US market for 2003. Now 80% of Nissan vehicles in this country qualify as ULEV. Therefore you're wrong again.
The Pats are going to win the SB. Philly just isn't good enough to beat them.
Old Jan 26, 2005 | 08:05 PM
mdloops's Avatar
Why would they make all the room for a 4L when all they would have to do is tweak the 3.5L to make the same HP as the g? They could easily get an extra 30 HP out of the 3.5 with a little minor modification. They squeezed out an extra 10 for the 6thgen without changing much. They could do a new IM, exhaust, ECU.
Old Jan 26, 2005 | 08:10 PM
SR20DEN's Avatar
VQ Wizard
No one said that it was really going to happen. But it does appear that Nissan has finally figured out American tastes for torque. Yes you can squeeze alot more power out of a VQ35 but what you can't do is get alot more low end torque of it. And as the Maxima becomes bigger and heavier it will need a larger engine to keep up.
Old Jan 26, 2005 | 08:22 PM
rastab97's Avatar
Thankfully, Nissan didn’t neglect the engine on the new model, featuring an all-new tall-block version of the VQ-series V-6. With a nearly 10mm increase in stroke over the VQ35, the still-oversquare VQ40DE cranks out a V-8-like 270 horsepower at 5,600 rpm, and 291 lbs./ft. of torque at 4,000 rpm. The only transmission available with the Pathfinder is a version of the Titan and Armada’s 5-speed automatic. Fuel economy figures are the same as the ’04 model, at 15/21 city/highway for the 4x4 model, and 16/23 for the two-wheel-drive version.
Now with this information it says a all new tall block version. this may mean that the block was just lengthen. it is still VQ technology. now with 3.5 heads the compression could be raised. just like the 3.0 heads and 3.5 block.
I think it would be possible.
Old Jan 26, 2005 | 08:23 PM
maxspeed96CT's Avatar
The original VQ...
[QUOTE=Frank Fontaine]My hunch is that with Nissans being hard enough to move off the lots (here we go again, Titan out in the 2nd year, REBATES. Altima, REBATES. Maxima, REBATES. Shift_Resale? No, S**T resale. Actually, there are 2, yes two, Nissan models that don't have a rebate right now, and that is the Murano and 350Z. Can you believe the brand-new Pathfinder qualifies for a $500 college rebate? And the Mexican Sentra, $2000 rebate. Yes Virginia, Nissan's lists are artificially inflated. They are designed to be sold with rebates. Too bad for anyone who buys one without, because they can subtract the rebate right out of their trade-in value after 1 year.)
QUOTE]
thats why you buy your cars cash, you can get a way better deal than with any rebate
Old Jan 26, 2005 | 08:26 PM
SR20DEN's Avatar
VQ Wizard
My only point is that once you stray from the original block dimensions you should consider changing the name as well. Yes it shares much of the older VQ technology but this one is vastly different from the earlier VQs. And it is probably too tall to fit in the A34 chassis.
Old Jan 26, 2005 | 08:29 PM
VIP Maxima
i think there is a very big chance that the redesigned 6th gen or the 7th gen will be using the 4.0 VQ
20% the 6th gen. 80% the 7th gen
Old Jan 26, 2005 | 08:33 PM
rastab97's Avatar
do you agree that the VQ30 and VQ35 are different. Well what could be the big difference between the VQ35 and theVQ40? the length of the block. I'm just talking about using the block write now. I'll have to do more research on the heads. because of the computer control.
Old Jan 26, 2005 | 08:42 PM
FanaticMadMax's Avatar
Hmm.......GUYS.....the Nissan 4.0 is not a V-8. As far I know a lot of car with the 4.0 configuration usually is a V-8 but Nissan's is a V-6. I hate toot my own horn, You guys are soooooo WRONG!
Old Jan 26, 2005 | 08:44 PM
To someone who leases, maybe so. But to someone who buys, it's very important to understand that the dealership cannot pay you more for your trade, than what they pay to purchase from the mfg. That means if you bought a Titan last year, regardless of what deal you received, good or bad, when 9 mos. later Nissan announces a $1000 rebate on it, you immediately lose $1000 in trade-value.
If Nissan has an excellent margin, a point with which I agree, that's great for Nissan, not the consumer. Or are you saying that's somehow good for the consumer? The fact that they can offer a $2000 rebate on a car that costs as little as the Sentra does, or $1500 on a 4 cyl. Altima, supports the great margin theory. The list is artificially high. That's how sales tend to work, you offer a discount off of a high price, to get a consumer to bite.
As I said, EVERY model of Nissan currently has a rebate on it, including the brand-new Pathfinder, except the 350Z and Murano. Name one other car co. that does that. Good luck, and happy rebates.
Old Jan 26, 2005 | 08:52 PM
konak85's Avatar
Are there anymore Nissans still made in Japan anyway?
Old Jan 26, 2005 | 10:51 PM
FriscoMaxima's Avatar
for some reason this made me think of Tommy Kaira's Edition of Nissan Skyline R-34
Old Jan 27, 2005 | 10:41 AM
The original VQ...
I hope it comes with a 4.0 as an option soon and it probubly will.
The altima has a 3.5 now and its a tiny bit faster than the max, i always thougth the maxima was the top sedan!!
Old Jan 27, 2005 | 10:49 AM
SR20DEN's Avatar
VQ Wizard
The Maxima still is the flagship sedan. It's just no longer the quickest sedan.
Old Jan 27, 2005 | 12:01 PM
liqidvenom's Avatar
brotherhood of tq
well the xterra or somthing had a s/c vq and that never made it into a max so therer's nothing saying that a 4.0vq is gonna land into the max.
Old Jan 27, 2005 | 12:16 PM
CoolMax's Avatar
is invisible
A 2 door RWD with turbo would NOT be a Maxima.
Old Jan 27, 2005 | 02:16 PM
acidspit86's Avatar
a homer simpson quote, god that episode was funny.....
Old Jan 27, 2005 | 07:49 PM
Kevon1's Avatar
No it did not
The Xterra had a supercharged engine. But it was no VQ engine. I dont even know if the engine in the original xterra was made by nissan?
Old Jan 28, 2005 | 05:47 AM
What's so interesting about Nissan design philosophy is that they seem to experiment at the production level (not just with styling). What I mean is look at the difference between the 1999, 2000, 2002, 2004 Maximas as far as the motor goes. Release now, refine later.
Did you know that there is a 2005 330i performance package that goes 155 mph? Does 0-60 in 5.9, and it's not even M? That's the German way--it's all in there, just a question of whether it should be unleashed. Japan unleashes it even if the chassis isn't up to snuff. The 4th gen already can do in excess of 130 mph without any chassis to back it up. Now the Max is up to what, 265 hp with no chassis to back it up, how much more does anyone want?
Then again, I know, the audience is not sophisticated. They slap a round LED into the stock tailamps and say look, LED tails! Who cares if the driver behind knows whether the car in front is braking or why the lamps are crooked on one side with dual exhausts. BMW has adaptive brake lamps standard on the 325 base model, where engineering actually went into them (cool, leds!). But their engineers forgot the fake dual exhausts.
Old Jan 28, 2005 | 07:05 AM
Turk's Avatar
Hey there are honda accords that are 2 door FWD. Hey i could dream can i. Same goes for the BMW 2 and 4 door. Ok i think i really pushed it with the turbo. How about 4 door maxima with RWD. Thats about it.....TURBO!
Old Jan 28, 2005 | 02:47 PM
anthunny's Avatar
i want a mid 13 maxima out the box =)
Old Jan 28, 2005 | 03:15 PM
monty95's Avatar
I heard somewhere, i dont remember where, but Nissan is thinking about making a maxima coupe sometime. I may have heard wrong...but imagine how that would look....
Old Jan 28, 2005 | 03:21 PM
Jeff92se's Avatar
I'm needing a caw
A rwd 2-dr maxima is here. It's call the M35. You want a rwd 4.0 maxima? It's call the M45.
SR, who did the 4.0 maxima swap??
IMHO, if the next gen max uses the Altima/murano chassis, I could see a 4.0 V6 IF it's also awd.
Old Jan 29, 2005 | 10:15 AM
mdloops's Avatar
Can somebody explain to me the logic of increasing the engine size to 4L when they could use the 3.5L platform and create almost 300HP?
