How to clean and restore plastic headlights by Dave Holmes
Old Feb 1, 2005 | 07:11 AM
kingrukus's Avatar
no more maxima...
The below is a write-up from Dave Holmes on how to clean/restore your plastic headlights.
Originally Posted by Dave Holmes
The following is the procedure I used to wet-sand and polish my pitted plastic headlights. Others may get varying results because of the many variables that are beyond my control. I tried to "bubba-proof" the write-up so people of varying experience can still achieve good results. I apologize if some of the info seems to be on a basic level, but I don't know other people's experience and expertise. For product selection, there are many good ones out there. I put what I use mainly as a guideline, but others can certainly give similar results. If you have a preference for another, use it. I think the best results are obtained mainly from technique, and not by any one magical product. I personally use Meguiars Professional Line stuff because it gives me outstanding, consistent results everytime. I can also obtain it locally without costing an arm and a leg, and it is what I have the most experience with. 3M products are also very good, as well as some others. Use what you're comfortable with.
Here's some pics of before, during, and after.
Driver's before, lights on:
Driver's after, lights on:
Passenger before, lights on:
Old Feb 1, 2005 | 07:12 AM
kingrukus's Avatar
no more maxima...
Passenger after wet sanding with 2000 grit, lights on:
Passenger lights off (left=sanded&polished, right=sanded):
Passenger after wet sanding and multiple polishing steps:
What they should look like when completed. Notice no yellowing, haze or pits:
As you can see from the pics, mine were pitted on the upper halves pretty bad. They were yellow prior to starting, but I had removed the yellowing with Mother's Mag and Aluminum Polish before I thought about taking the pics. The pitting resembled sandblasting, and was really noticeable with the lights on depending on viewing angle. I attempted to take the before and after pics from the same angles, distance, lights on/off, etc, but the human factor comes in to play. They're close enough that you can easily see the differences.
I started with 1500 grit 3M Imperial wet/dry sandpaper on a rubber 3M sanding block. The paper had been soaking in a car wash soap (normal mixture) solution overnight. I also used a spray bottle of car wash solution to keep the surface drenched, and rinsed the block/paper in solution very frequently (to keep the paper clean). I did vertical, then horizontal strokes, using slow, deliberate strokes with moderately light pressure. We're not removing rust or paint, just leveling the surface, so there is no reason to scrub. I suggest using light pressure to begin with, and increase pressure only if needed and only after you get a feel for it. This will save you time in the polishing steps so you won't be removing any unnecessary, deep sanding marks from being too aggressive at the start. To check my work, I used 3M Fine Cut Rubbing Compound (part # 03900) on a foam applicator to "polish" the sanding marks every so often to see if the pitting was being removed. When almost all the pitting was removed, I switched to 3M Imperial 2000 grit paper, following the same routine, but decreasing my pressure with every few strokes. When satisfied with the sanding, I did one or 2 passes with the 3M Fine Cut Rubbing Compound on a PC with a 4" cutting pad to remove the bigger sanding marks. I followed with Meg's DACP (#83) on a 4" cutting pad until only light surface marring remained. Meg's Swirl Free Polish (#82) on a 4" polishing pad was next and removed all light marring left from the previous steps. Continue polishing until you have the results you desire, which should by now be as close to flaw-free as you can get it. If it's not, you can repeat the DACP step, and then step back down to SFP again. These polishing steps will take several passes each, so take your time with it. When the surface meets your approval, I suggest applying a sealant like Meg's NXT or Klasse to prevent yellowing (oxidation) from returning. It also makes future cleanings of the lenses much easier. The polishing steps could be done by hand, but it would take longer. If you don't have a PC with various pads (including the handy 4" spot pads), I whole-heartedly recommend one if you're serious about detailing and you have about $200 total to spend on it. That would get you a PC 7336 (or 7424) and a good assortment of pads. Check www.autopia.org for more info on PC's and pad suppliers.
All in all I'd say they look much better. It took about an hour per light, so it wasn't too bad. The main thing is to take your time, use light pressure, and keep the surface drenched while sanding. Did I say take your time? That is probably the key to achieving good results, along with constantly checking your work. I only used one piece of 1500 grit and 2000 grit wet sandpaper per light. I also could have skipped the 3M Rubbing Compound and just used DACP for the main polishing of sanding marks, but I felt the 3M was more aggressive and saved a little time polishing (and I had a bottle from a previous project). There are other polishes that would work (3M's line comes to mind), but they must be actual abrasive polishes, not the stuff like Meg's Deep Crystal Step 2 or Mother's stuff you can buy at Auto Zone. #83 and #82 are both in Meg's Professional line, available at most Paint, Body & Equipment shops (auto paint suppliers) or online. They are my favorite polishes for scratches, swirls, and blemishes on paint, and work equally well on plastics. These 2 together can take care of just about anything my car's paint or headlights ever see, and simply do an outstanding job. They are the backbone of my detailing arsenal.
That's about it for wet sanding headlights. Same would apply for tails, corners, etc.
Dave
Old Feb 1, 2005 | 07:35 AM
Zero Deuce SE's Avatar
Great post. Maybe they will make it a sticky.
Old Feb 1, 2005 | 08:15 AM
1MAX2NV's Avatar
I used to polish plastic in HS shop class. We used steel wool and then a buffing wheel with plastic polishing compound. I guess 2000 grit is about the same as #0 or #00 steel wool.
Old Feb 1, 2005 | 08:34 AM
sagamax's Avatar
Give me a Bud Light Holmes
brake fluid works well 2
Old Feb 1, 2005 | 09:48 AM
Maximan190's Avatar
didnt do this on my headlights since 3rd gens have glass headlights
but i did do it to my front bumper lights following the same idea - i used regular car polish i had laying around and it came out great
Old Feb 1, 2005 | 08:37 PM
kingrukus's Avatar
no more maxima...
Good idea with the bumper lights, I am sure mine will need that treatment as well.
Old Feb 1, 2005 | 08:38 PM
AKANeedles's Avatar
Great writeup.
Old Feb 1, 2005 | 10:35 PM
Nismo3112's Avatar
Custom User Title
Wow.... Major difference. Nice.
Old Feb 1, 2005 | 11:00 PM
Maxima99SE's Avatar
will fly for food
awesome, i definitely am going to do this...
Old Nov 6, 2005 | 02:03 AM
packetattack's Avatar
Thanks Dave
Following Dave's writeup, I put up a guide as well with pics as well showing just how nice they can come out. My method is a little different from Dave's as I used Novus products in the end.
Have a look
http://forums.nycmaximas.org/showthread.php?t=6432
Old Nov 6, 2005 | 09:53 AM
kingrukus's Avatar
no more maxima...
Nice results. I still have yet to complete this but I definitely will for my retrofit.
Broken pic links have been updated.
Old Nov 6, 2005 | 11:19 AM
gtr_rider's Avatar
192.168.1.1
really nice..
Old Jan 9, 2006 | 08:29 PM
kingrukus's Avatar
no more maxima...
Well I finally got around to doing this to a spare set of headlamps today that I am prepping for my projector retrofit.
I started with 400 grit wet sand paper, went to 800 grit, then to 1500 and finally 2000 grit. I used a buffing wheel attached to a power drill and used some 3M polishing and scratch remover. The lights were pitted really badly and looked like they were sandblasted (they have seen 6 or 7 canadian winters with a ton of salt/sand). They came out great and could have looked brand new had i spent more time on them.
Old Jan 19, 2006 | 06:06 AM
maxrf's Avatar
I need to try this looks amazing, and my lights barely work now b/c they are so dirty
Old Jan 25, 2006 | 07:32 AM
pest55's Avatar
I know some guys who have done this to their chevy trucks with great results.
Old Jan 25, 2006 | 09:30 AM
Dubbya's Avatar
VK56 Inside
^ so what does that have to do with a maxima?
Old Jan 25, 2006 | 08:25 PM
1995 MAXIMA se's Avatar
thanks for the tip NOW i know im going to do my maxima and my gas eater
Old Jan 26, 2006 | 10:17 AM
JSMax's Avatar
Sold
just wanted to add this to my subscriptions...
Old Jan 26, 2006 | 12:13 PM
C MAX's Avatar
same here, im tired of buying new lights when they get dull
Old Jan 26, 2006 | 12:50 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
This should be a STICKY so it doesn't get buried
Old Jan 26, 2006 | 03:32 PM
GBAUER's Avatar
Ditto! I'm going to do this once winter's definitly gone!
Old Jan 26, 2006 | 07:15 PM
irish44j's Avatar
retired moderator
great writeup...I'll practice on Bauer's before doing mine.
Old Jan 26, 2006 | 09:26 PM
mybigDEK's Avatar
From: i repped the coast of ms for a while. now im a resident of dallas area. i'll see how it goes.
great info. i will be trying this out this weekend!
Old Mar 31, 2008 | 08:10 PM
CautiousDriver's Avatar
is it truly all outside? an not the burn in efect fromthe inside? when i feel the head light from outside it's smooth how can all this foginess be outside? i think i have to open the headlight and if someone tells me this will work i will get this done
Old Apr 1, 2008 | 10:18 AM
matty's Avatar
Its outside. Its the plastic getting weathered
Old Apr 1, 2008 | 10:03 PM
Lordrandall's Avatar
Great write up. 8-)
Old Apr 7, 2009 | 03:06 PM
80mixam's Avatar
I had tried the process that nycmaximas site offered, using 800, 100, 1500 and 2000 grit paper and the 3 levels of Novus polish. The plastic became even foggier (looks more scratched as well). The assemblies remained mounted in the car. Is it ppossible that mosture went to the interior? Feels relatively smooth on exterior; if internal moisture is unlikely, maybe the problem is that I had only used hand to wet sand and buff, and spent a minute or so on each step (each grit and polish level). Should I consider a sanding tool and polishing tool, or simply spend more time on each step?
Old Apr 7, 2009 | 04:24 PM
I VIK I's Avatar
I did mine with a mothers powerball and plastic-X on my corolla. I did not wet sand but I think I got lucky and got the same results.
Old Apr 7, 2009 | 04:38 PM
anomaly117's Avatar
seriously?? either way i gotta do somethin. mine look like hell. i was almost thinking of just buying new lights. i want the ebay projectors anyway.
btw VIK, i use plastic-x all the time and it keeps coming back. maybe i used it wrong? what process did you use when you polished with the plastic-x?
p.s. at the risk of sounging like a n00b, how does one wetsand. ive never had to do anything like that before
Old Apr 7, 2009 | 06:22 PM
Leo_Koneval's Avatar
Haha I think I invented a shortcut by mistake.......but what I did was sanded the lights down with coarse paper then super fine sand paper and then I washed it and then clear-coated the lights, and the results still has some fine lines, but I did it only for the corner lights and the bumper lights because the headlights would probably have too many lines.
The clearcoat fills all the lines and then creates a mirror like surface that really amplified the lights but not very much. But yet again, I am not sure if it will peel or go back to being dull from the sanding, BUT its been two weeks with Washington weather taking a beating on the clearcoat and it still looks good, considering the amount of time I took LOL
But overall if you want something to shine like glass, the original method is still KING!
Old Apr 20, 2009 | 08:16 PM
maxima dude's Avatar
niceee
Old Jan 15, 2011 | 10:15 PM
Maxima1802's Avatar
May need to give this a try. Thanks.
Old Jun 12, 2012 | 07:00 PM
FieryOnyx's Avatar
Hi, I am new to the forum, as well as anything car related. I have joined this forum to learn more about how to properly maintain and take really good care of my 2002 Maxima. I have VERY dull headlights and have been shopping around for help. How long does this process last of protecting the headlights? If it would cost about $200+ dollars on supplies, would it be better to buy a pair of $250 new headlights? I would really like to make improvements concerning my car; and I'm starting with these headlights. So any help is appreciated.
Old Jun 12, 2012 | 07:57 PM
Amerikaner83's Avatar
3M headlight restoration kit. under 20 bucks.
/thread
Old Jun 12, 2012 | 08:59 PM
2brosgixxer's Avatar
/thread
Pics of said 3M Resto http://forums.maxima.org/8359452-post31.html
Old Jun 12, 2012 | 09:01 PM
^^^ yes indeed
Old Jun 14, 2012 | 11:01 PM
FieryOnyx's Avatar
/thread
What are all the supplies, tools, and everything else I will need for it as well? How well does it work and how long is it effective? I bought this car from my cousin about 2yrs ago. It's had thousands of trips back to NY, and has been through rough winters. But I don't plan on going to NY like she did with it. Will a kit work well enough with it? >.> Or even the fact that I know nothing? Will I be able to do this myself? I will go click those links now to look what else was posted. Thanks!
Old Jun 14, 2012 | 11:19 PM
ShocknAwe's Avatar
the 3m kit is good and if it doesn't fix em I would be very surprised
AaronL
Nov 15, 2020 11:52 AM
Vistance
Sep 17, 2015 05:17 AM
seesole
Sep 14, 2015 12:38 PM
mpbclutch33
Sep 8, 2015 06:21 PM
sdotcarter
Sep 2, 2015 09:53 PM
