yellow fog capsule?
Old Feb 2, 2005 | 12:29 PM
2kprlmax's Avatar
yellow fog capsule?
I know someone has done this but I wanted to see how they did it. I got this from HIDTECH and wanted to compare:
Please also note that they don't just insert over your existing halogen bulbs and then insert from behind the foglight. You will need to separate your front clear housing first, then secure yellow capsule onto your reflector housing by simply drilling three small holes and clip the tabs from the bottom of the yellow capsule in, then seal the front clear cover back.
Also for H3, it only come with yellow glass capsule without bottom metal bracket, we will also provide you a pair of metal bracket from 9006 type, but you will need to trim it sand it a little to fit Yellow capsule over, its quite a bit modification involved, well, if you are able to take apart your housing, modifying is nothing compare with all your other effort. If you are not ordering H3, you can disregard this paragraph.
In addition, we have experienced that some foglights might create fog due to excess heat trapped inside the yellow capsule. Again, your OEM halogen housing is not designed to fit yellow capsule over, so this mod MIGHT require you to down grade your 55 watt set up to H8 35 Watt set up. Actually 35 watt is pretty bright enough for the foglight.
Old Feb 2, 2005 | 12:37 PM
1SICKLEX's Avatar
For the Lexus look on your Maxima?
Old Feb 2, 2005 | 02:45 PM
2kprlmax's Avatar
yes that is correct
Old Feb 3, 2005 | 08:53 PM
Puppetmaster's Avatar
Talk to Irish44J... he did it... there was someone else who started it.... but I forget who...
Old Feb 3, 2005 | 09:01 PM
... okay its AKOGAN and here's a link to his thread with a write-up, comments, etc...
http://forums.maxima.org/showthread....ow+fog+capsule
Hope this helps....
maxspeed96CT's Avatar
The original VQ...
I just got yellow H3 bulbs off ebay and it looks very yellow to me?
Old Feb 4, 2005 | 07:16 AM
2kprlmax's Avatar
hidtech charges:
Our labor will be $120 (for Plastic foglight front cover only. We don't do glass) including return shipping for your foglights.
Old Feb 4, 2005 | 07:18 AM
Santa29's Avatar
120 to me is a lot 2kprlmax. I got the same email from them before. I was thinking about doing this as well. I think its almost the same steps as doing DDEs, except working with fog lights instead of the headlights. From Irish's site, it doesn't seem too hard. I was thinking about getting my friend who does DDEs on the regular to help me with it. Still comtemplating it through, i just don't like baking stuff. LoL
Old Feb 5, 2005 | 09:08 AM
evoMaxi
Check out MotionR 6000k. They outperform Silverstar, Sylvania/osram, PIAA, Phillips and more.
http://www.motionr.com
Testimonials:
http://hyundaiperformance.com/forums/topic.php?t=8938
http://www.cardomain.com/member_page...page_id=374204
http://www.toyotanation.com/forum/sh...threadid=19415
http://www.sonataspeed.com/yabbse/in...17225#msg17225
http://www.j-body.org/forums/read.ph...07861&t=207861
http://www.topendmotorsports.com/mem...searchid=11937
http://www.toyotanation.com/forum/ar...c/19071-1.html
Old Feb 5, 2005 | 07:00 PM
irish44j's Avatar
retired moderator
I've done it, but AKOGAN's write-up is much better than mine...
Puppetmaster already linked you to his...here's mine
http://www.cardomain.com/memberpage/442543/15
There are several threads on this subject in the 5th-gen specific forums.....
Fbana41
Aug 29, 2016 12:18 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
