Do you clean your 4th gen's "secret spots?"
Old Apr 28, 2001 | 04:14 PM
pmar's Avatar
When cleaning your bad-boy make sure to open the trunk and clean the spots under the spoiler, as the spoiler is wider than the deck lid. If you miss these spots, you'll see two very funny spots on your rear quarter panels. Check it out!
Old Apr 28, 2001 | 04:32 PM
LoveSick's Avatar
I clean even the door sills, bottom of the trunk lid sides, hood lid sides and engine department. I also clean the back of the door and its panels. Once a month, I place a water sprinkler under my car and clean it.
Old Apr 28, 2001 | 06:13 PM
Eric L.'s Avatar
Yikes! A sprinkler under your car???
Oh, why do you run 15w50 synthetic in your Maxima?? The owners manual recommends 5w30 or 10w30. 15w50 flows like mollasses in comparision to the thin stuff (even if it is synthetic).
Old Apr 29, 2001 | 11:57 AM
Empz's Avatar
Why whats wrong with this???
I've did it last week to do a Underbody wash after the Winter to get all the Salt and crap out!
Old Apr 29, 2001 | 12:57 PM
NightRider's Avatar
15w50 synthetic is a bit thick. I run 5w50 synthetic, with no problems. I believe I drive hard enough to use an oil with a higher viscosity rating than 5w30, which is also used in Buicks.
Old Apr 29, 2001 | 01:01 PM
metallic97gxe's Avatar
Master Will
me too I do the same..it helps to have an internally and externally clean car
Old Apr 29, 2001 | 01:15 PM
Nealoc187's Avatar
SLOW
cleaning the underside
cleaning the underside of your car is the best protection against rust that there is. moisture and salt underneath mud accelerates the cathode-anode reaction that strips away electrons and causes iron to rust.
Neal
Old Apr 29, 2001 | 05:44 PM
pmar's Avatar
[i]I believe I drive hard enough to use an oil with a higher viscosity rating than 5w30, which is also used in Buicks. [/B]
Buicks, and Corvettes too. the 15w is probably ok as long as the temps never go below 50 degrees, but that's not too many places. It's like 10W 30 and 10W 40 in the old days, people debated which to use when it really didn't make any difference. If 10W 40 were better it wouldn't cost the same. And people buying Mobil 1 would be idiots to pay so much for 5W 30 if it weren't a good all-around weight.
stevesmax
Dec 17, 2020 11:57 AM
Finkle
Sep 27, 2015 09:53 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
