P1320 trouble code help
Old Feb 6, 2005 | 10:24 AM
Hedge's Avatar
Ok my check engine slip and TCS lights have all come on three times now even after having them cleared out. I get the same code all three times which is P1320 and most people are saying this means replace the coilpacks. However most posts I have seen about it show the code with another code telling you which clynder to replace it on but I am not getting any second code. 1 time I got two codes but they were both P1320.
I know all 6 can not be bad so it would be nice to know which one was bad if that is the problem. My other concer is if I am not getting the second code does that mean the problem might be something other than the coilpacks? Anybody else had any experience with the P1320 code?
Old Feb 6, 2005 | 05:38 PM
C MAX's Avatar
no thats what it means, that one of your coilpacks is probably going bad. do a test on them to determine if one is faulty. holding it with the plug facing you test terminal 1 and 2 starting from the right to the left if you get o resistance its no good if you dont get 0 its good.
Old Feb 7, 2005 | 01:11 PM
PearlWhtMaX2000's Avatar
my advice is to change all of the, they will go eventually one by one.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
