polishing parts?
Old Feb 6, 2005 | 09:40 PM
craig10114's Avatar
polishing parts?
so i was hopign to get just a general right up of how to polish parts in the engine bay.
Id like to do my intake manifold as well as the timing chain cover and a few other odds and ends and was hoping for some direction to start the job.
any help would be awsome
`craig
Old Feb 7, 2005 | 11:29 AM
craig10114's Avatar
bump......
Old Feb 7, 2005 | 03:38 PM
FanaticMadMax's Avatar
What's the point of polishing your engine bay, unless it's for car show. Otherwise, if it's your basic daily car, it's not worth doing so, cuz it's bound to get dirt and other grime into the engine.
Old Feb 7, 2005 | 05:15 PM
Bluesbrekr's Avatar
Doctorate in Detailing
I enjoy polishing stuff in the engine bay. Yeah, it gets dirty, but it sure looks nice when it's clean.....
Old Feb 7, 2005 | 08:14 PM
95CustomMaxima's Avatar
Why would you want your engine bay polished?
Old Feb 7, 2005 | 08:50 PM
doublea's Avatar
`craig
Check this out: http://www.caswellplating.com/buffs/index.html This is where I buy my stuff for polishing, if you have a good bench grinder you can buy a kit for less than 100$.
Good luck
Old Feb 7, 2005 | 10:15 PM
505max94se's Avatar
Polished stuff needs ALOT of upkeep to keep it shiny (if it's your daily driver).
It gets dirty and dull over time and the slightest little thing will scratch it. It also takes ALOT of work to do a good polishing job. I polished my valve cover and I'm thinking about getting it powder coated with a clear powder to protect it. The more pitted the metal is the more work for you so good luck with the IM.
Old Feb 7, 2005 | 10:19 PM
|Bijan|'s Avatar
UCF Lexus
IMO its worth it. Polished valve covers and intake manifolds look sooooooo sexy.
Old Feb 8, 2005 | 07:42 AM
maxspeed96CT's Avatar
The original VQ...
do you mean polish the inside of the manifold or the outside?
cause i have an extra manifold laying around and im wondering if i polish the inside, would it speed up air flow alittle bit?
Old Feb 9, 2005 | 02:14 PM
s0ber's Avatar
How did you polish those little things? lol looks chromed.
Old Feb 9, 2005 | 03:31 PM
Bluesbrekr's Avatar
I use a Dremel with a variety of attachments - steel and brass brushes, felt cylinders and cone tips and Mother's Mag and Aluminum Polish. With a bit of work they shine up rather nicely.
Old Feb 9, 2005 | 05:23 PM
Maximus_95's Avatar
i want to do this too. my engine bay is nasty right now.
Old Feb 9, 2005 | 05:34 PM
Broaner's Avatar
2060lbs and falling...
Wow, that is a very nice site with lots of nice kits. I'll be ordering mine tomorrow. With those kits how long does it take on smooth metal? Let use the valve cover as an example. How long would that take?
Old Feb 10, 2005 | 03:46 AM
pruizgarcia's Avatar
Good work, looks awesome.
Pedro
Old Feb 10, 2005 | 07:35 AM
ny96max's Avatar
if you can search look for a write-up that i did a few years back. It will explain everything youll need to know
Ant
Old Feb 10, 2005 | 07:43 AM
doublea's Avatar
Ant
Hey ny96max, your car is really hot, where did you get the radiator hose ?
Cheers and keep up the good work
AA
Old Feb 10, 2005 | 07:50 AM
DanNY's Avatar
Ad·min·is·tra·tor
AA
they sell braiding that you can slide over the stock rubber hose.
Old Feb 10, 2005 | 08:35 AM
s0ber's Avatar
Damn, I thought that was all chromed.. lol
Someone search for his writeup :P
Old Feb 10, 2005 | 09:54 AM
Maximus_95's Avatar
yeah, im interested on the write up as well. i hope someone finds it, ill be looking for it also myself. =)
Old Feb 10, 2005 | 06:13 PM
ny96max's Avatar
the only things polished by me are the intake manifold, valve cover and timing chain case. EVERYTHING else is chromed!
...and i do mean everything else, nuts, bolts, brackets you cant even see where all chrome dipped. Me, Tony and Jay S. were chrome freaks back when Jay and Tony had their max's.
Ant
Old Feb 11, 2005 | 06:32 PM
doublea's Avatar
Now you know my secret. Fore most it will depend on the buffer you have the faster the buffer spin the quicker the job can be done with the right technic, ça vas de soi, but typically you have a 3 steps buffing so it would probably take near 3 hours but many other factors can play in the time it take to do a good job.
AA
Old Feb 11, 2005 | 10:13 PM
Broaner's Avatar
Actually I haven't ordered mine yet. I have some Q's? I have a high speed plug in drill. Will that work well? What is the difference of a buffer and a drill? RPM? What is the max RPM of the tool you use?
Old Feb 12, 2005 | 07:13 AM
doublea's Avatar
A bench grinder would be better than a drill for shure, the rpm range is between 3700 to 7000 rpm, anything around 4000 rpm would do a great job. When you polish you dont want to have the buffer to slow down all the time, an ideal buffer would keep is speed even when you apply pressure ( not to much though, otherwise you'll end up with burned spot ) my 1/2 hp bench grinder is quite good for now but I'm ordering a 3/4 hp motor with extended shaft and a stand, it give you much more room and freedom to buff.
Old Feb 12, 2005 | 11:04 AM
Ceasars Chariot's Avatar
Old Maxima Legend
someone dig up the detailed post on chroming by ny96max, i have some spare parts also i would like to get them shipped over and start working on them.
Old Feb 12, 2005 | 12:33 PM
Broaner's Avatar
I figured a bench grinder would be much better. I may be getting one shortly for free. Is the kit different for each tool?
Old Feb 12, 2005 | 04:16 PM
doublea's Avatar
You can build your kit based on what you want to buff, for example I bought the compound to polish headlamp, aluminum, SS, and all kind of metals.
Old Feb 12, 2005 | 07:01 PM
GodsmackMAX's Avatar
Here ya go guys!
Ant's Polishing guide
I think I'm gonna work on this as I have an extra intake manifold and about three bench grinders that just need to be hooked up and a stand made for one of them.
drew
Old Feb 13, 2005 | 02:59 PM
craig10114's Avatar
awsome thanks for the seach and the AWSOME find
Old Feb 13, 2005 | 03:01 PM
craig10114's Avatar
just a quick question though theres 2 differnt right ups, whats the pros and cons of using the first method with just the polish and would that work with the intake manifold as well or would u ahve to sand the intake manifold down before polishing it?
Old Feb 13, 2005 | 03:48 PM
Bluesbrekr's Avatar
I know a couple guys that did their 4th gen intake manifolds. Sanding first works best because its a pretty rough surface. After going through the different grits, you can start to polish.
Old Feb 13, 2005 | 06:00 PM
ny96max's Avatar
i knew someone would find that eventurually!
goodluck with your polishing boys.. any questions just e-mail me.
Ant
derekinthez
Nov 13, 2022 04:00 PM
Mar 12, 2020 12:06 AM
SpeedCrazie
Sep 16, 2016 03:41 PM
videomano
Sep 8, 2015 03:28 PM
Max139617
Sep 6, 2015 06:02 PM
