e46 vs rs6/a6 bixenons vs e55
Originally Posted by maxima8624
^^ sure they do
I need to reaim mine
Originally Posted by BlueC
Yes, mine need it to, but Its hard to get them to be level with my setup. They slant slightly to the right, but it is aimed to NOT effect oncoming traffic. But hey, other drivers dont notice it, so it works for me.
Originally Posted by Nismo3112
Hey do you have any pics of your installation?
As for aiming, I have full up/down and left/right adjustablility incorperated into my housing. As for the cut off line being horizontal, I eyeballed that
Originally Posted by Rowan
hmm, didn't know that. Does the beam pattern start flat then gradually misalign?
Actually, I meant, do they tend to move and thus go out of alignment over time.
(I do know about DOT vs ECE cutoffs
mbsup: )
ok so I finally found the powerpoint presentation link with the how2! (Just so it's all in one thread)
http://rishisingh.info/max-projects/...CTOR%20DIY.ppt
Tl's are really hard to find. Where did you get yours?
They are made by Stanley, the same company who makes those in the s2000 but they are different projectors (albeit with very similar beam patterns, cutoff, color, etc). S2000's are single xenon.
News: I just bought a set of E46 bi-xenons for 385 shipped! I think it's a pretty good deal and I'm psyched that I have a new project to work on! Let me know what you think!
Nismo3112, what did you mean when you said you mounted yours on springs? I can't really tell where the springs are in your setup. Is it different than what the powerpoint presentation says to do?
Here is what I bought...
ebay link: http://cgi.ebay.com/ebaymotors/ws/eB...tem=7961869555
Anyone know what gen ballasts those are? Should I bother upgrade to gen 3 if those are older versions? Thanks.
^^ Those are the same exact ballasts I have. I think they are from 02 and up BMW's, so they should be new-ish. I mounted the projectors on springs, so they would be adjustable with 4 nuts, 1 nut on each corner, the 4 springs would hole it in place. Once the projectors are perfectly aimed, I will seal any holes with sealant. The springs are behind that nut on the bolt, that is towards the middle of the pic.
Success! Finally got that straight beam patten I was looking for. For a long time both projectors were slanted to the right, making almost a v-shape beam pattern, very messy. Experimented with the headlights a bit today on my day off, found a way to give more space for the structure of each projector, now both projectors sit perfectly flat. Makes driving at night much more fun!
I will have pics sooon.
blue c post some beam picks! I look forward to seeing them!
So for anyone that is too lazy or not knowledgeable enough to make their own wire harnesses to make their retrofits plug and play (including the bi-xenon high beams), there is a guy on hidtech forums that does them for 45-90 bucks. His screen name is Doh Doh and his e-mail is doh-doh7@excite.com
oh man, I'm going to try to tackle this project this summer. I think I can easily do the fitment of the projectors into the housing, but I'm not to sure about the wiring part. That seems a little hard to me. I dont know the first thing to do with wiring. I thought it would have been plug and play. Take the old wires and plug it into the projectors. The way yall are talking it seems its more difficult than that. I just called around for some TL bi-xenons so hopefully I can get a good deal. If not then I'll try some other bi-xenons.
Easier said than done. Id say the alignment part of the projectors can be the most difficult. Be prepared to get frustrated like none other, cause you'll be driving and notice any minor imperfection with the angle of the beam.
Ok here are pics of my new beam pattern, I am very pleased with the results of messing with the headlights and being frustrated all last evening....
Close up shot
Distance shot
You'll see, with projectors, up close it might look one way, but once you back out it really changes. Thats why aligning them is so frustrating. You have to go on test drives to get it right, so its very time consuming and involves LOTS of patience. I'm happy I FINALLY got it correct, Ive had projectors for over 6 months now and hadnt had it 100% correct. Thats how frustrating it can be.
Close up shot
Distance shot
pretty- very pretty! Did you do a washer mod? Your cutoff looks a tad more colorful and slightly less sharp than other e55 cutoffs.
Congrats on finally getting it done!
I am slowly learning that the Bosch E46 projectors are a pain in the a$$ because they seem to wire the solenoid and the ballasts differently than Hella. Hella only uses 2 wires for the solenoid but Bosch uses a couple extra=> more complexity in wiring. Argh.
I guess I should take it step by step get the projectors first (their on their way) and do the retrofitting before I think about wiring lol!
Im not very familiar with Bosch setups, im sure theres some info on hidplanet.com, but hopefuly it wont turn out too complicated. Good luck.
Hey wuts up guys. I am looking to get the e46 ece single xenon projectors from hidplanet. they are very good priced. wat can you guys tell me compared to the rest? like the e55 as far as distance and wideness. ? http://www.hidplanet.com/bosch.html. i am not doing bixenons. so i want the brightest single xenon possible. iv done a little reading and these are good. so wat can u guys tell me?
If you are not doing bixenons, that changes things. Make sure you have an additional headlamp (hard but possible) for a highbeam.
By far the best single xenon projectors are the S2000 and Mitsu Evo projectors. Period. Best cutoffs, best spread, best distance.
good luck.
good luck.
My fault Rowan, I didn't know this thread existed. Anyone with TSXs with beam pics? I'm planning on trying some e46 next then hopefully tsx. S2000 are way out of my league I think they have been going for around $500-$600 on eBay. I think the e55 bixenons on the 6th gens are pretty hot too.
Originally Posted by Iron Scimitar
I'd give up my e55's for a pair of TSXs and do the color mod.
Courtesy of haknslash.
I definitely need these!!!! The e55s were my first projectors so I'm kinda attached to them, I will let them go though. It's kinda like your first ever sub amp combo, to you it is the bomb!!
TSX Panorama shot
