Has anyone cut out the entire spare tire well?
Old Feb 24, 2005 | 12:36 PM
|Bijan|'s Avatar
UCF Lexus
Meaning completley........so it's almost perfectly flat from above and underneath.
If so what material did you use to seal it? Sheet metal of some sort right?
Old Feb 24, 2005 | 03:41 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I've seen that in mags for weight savings and cleaning up the airflow under the car.
Pretty extreme, but I'd say cut it out and then box it in for a relocated battery or fuel cell.
Old Feb 24, 2005 | 03:42 PM
Jeff92se's Avatar
I'm needing a caw
Just use 16-18 ga plate steel. Cut a template of what you cut out and tig weld in. Easy.
Old Feb 24, 2005 | 04:01 PM
Jepht20's Avatar
Custom User Title...
wouldn't that change the wind resistance or drag (whatever the hell that coefficiant thing is called that they test)? or would that be fine if you made it flat? just curious...
Old Feb 24, 2005 | 06:24 PM
RA030726's Avatar
I'm nutty for Nissans
one member did it, cant remember who.
Old Feb 24, 2005 | 06:28 PM
JamesNH's Avatar
Someone on cardomain did it and i think hes a member here i think is car is white. He just used sheet metal.
Old Feb 24, 2005 | 06:41 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
there is a guy in the 3rd gen section who did it to fit G35 mufflers...theregon or something like that is his sn
Old Feb 24, 2005 | 08:41 PM
ny96max's Avatar
you can do what Sadler did and just mash it so your dual exhaust setup fits
OR
neatly cut away the entire spare tire well and have a sheet of metal welded into place.
Ant
Old Feb 24, 2005 | 09:11 PM
IceY2K1's Avatar
I'd say if you're going to do this, might as well cut out the whole trunk floor and just use aluminum sheet, if weight reduction is the goal and you don't carry anything in it.
Old Feb 24, 2005 | 09:32 PM
«§»Craig B«§»'s Avatar
therealgoon9, he's actually in Atlanta also Bijan so you might be able to check out what he's done. I dont think he's completely finished yet though (at least last time I saw it). Da-max is right, he cut it out to fit the G35 mufflers.
Old Feb 24, 2005 | 09:37 PM
Larrio's Avatar
The Definitive AE Master
Cut a square shape around the perimeter of the spare tire well.
Stitch weld 18ga 304 SS angle metal to inside of opening, as a frame. Best to make the frame on a workbench to ensure it's square and level. Seal edges of welded area.
Rivet lightweight panel of carbon fiber to metal frame.
That's it. Shaved weight, and made a good place to attach rear diffuser.
Old Feb 24, 2005 | 09:47 PM
IceY2K1's Avatar
Okay Larry, I think that CF resin is seeping into your skin and affecting your brain.
Old Feb 24, 2005 | 09:56 PM
Larrio's Avatar
If you find CF resin anywhere, lemme know! We only use VinylEster and Epoxy resins. A panel of carbon fiber was chosen over metal because it's lighter, stronger, and reduces noise transmission.
Old Feb 24, 2005 | 10:00 PM
IceY2K1's Avatar
CF resin = resin used to make CF stuff...what's next CF valve stem caps, CF cig lighter, CF dipstick handle, nevermind.....
Old Feb 24, 2005 | 11:26 PM
Larrio's Avatar
i have made a CF frisbee and ashtray if you'd like. At a small nominal fee of course .. haha. Ok, back on topic
Old Feb 25, 2005 | 05:44 AM
cardana24's Avatar
Blown
If anyone does cut out their spare tire well, I have a 350Z muffler if you would like to buy it...pm me for details
Old Feb 25, 2005 | 07:33 AM
|Bijan|'s Avatar
UCF Lexus
Thanks for all your input fellas!
Old Feb 25, 2005 | 07:39 AM
mzmtg's Avatar
Minister of Silly Walks
Old Feb 25, 2005 | 07:59 AM
IceY2K1's Avatar
Let me know when you develop the CF condom, those would sell better.
Old Feb 25, 2005 | 08:12 AM
MrGone's Avatar
madmax024 did it aswell
Old Feb 25, 2005 | 08:19 AM
GoalieKeg's Avatar
JapmaxSE did it on his 4th gen. He's also got the hybrid motor setup.
Old Feb 25, 2005 | 08:35 AM
Larrio's Avatar
Originally Posted by mzmtg
Yeah, when is the original poster gonna put up pics?
If it's up to me, it will remain worthless.
Old Feb 25, 2005 | 08:37 AM
Larrio's Avatar
Who asked anything about engines here?
Old Feb 25, 2005 | 08:40 AM
Y2KSilvahSE's Avatar
now this I could use...LMAO
Old Feb 25, 2005 | 08:51 AM
GoalieKeg's Avatar
Just a reminder of who he is, since most people remember other members with crazy stuff like motor swaps.
Old Feb 25, 2005 | 11:01 AM
japmaxSE's Avatar
Go Get a Life!
I removed every inch of metal in the trunk, from one side of the frame to the the other side all the way up as close as I can get to the back seat. I used aluminum sheet metal it's very thin not sure how much thiner but it was very unstable so I had to use adhesive foam to fill up the gaps and sturdy it up. This job requires alot of patience so take your time
Old Feb 25, 2005 | 11:37 AM
1FSTMAX's Avatar
damn took out all the evap crap out..
Old Feb 25, 2005 | 11:57 AM
Larrio's Avatar
No offense japmaxSE, but that looks pretty ghetto. Seems like it would be flimsy, did you add any sort of reinforcement on the other side? Isn't it going to be a PITA to remove the rear bumper with all those screws on it?
Old Feb 25, 2005 | 03:03 PM
japmaxSE's Avatar
Go Get a Life!
Evap stuff is still there.
Old Feb 25, 2005 | 03:10 PM
japmaxSE's Avatar
Go Get a Life!
As far as it being flimsy I still can put groceries in the trunk oh and when I was changing out my rear speakers I had to lay in the trunk and I weigh 158LBS so I don't think it's flimsy.
As far as looks who looks under the car
Old Feb 25, 2005 | 08:23 PM
1MAX2NV's Avatar
I would use heavy gauge steel and weld everything in place.
Old Feb 25, 2005 | 09:44 PM
Xmax's Avatar
Hey wait a minute, not sure if this was brought up before, but that gives me a perfect idea of something crazy but not that crazy. I remember watching "Two guys Garage" and a buddy telling me how a turbo kit was mounted in a way that it was located in the rear of the car instead of in the engine bay where it can be very cramped because of the piping and every thing else I remember they have kits special made for F-body's. I know there is a name for this type of setup but I can't remember. Basically what im trying to say here is that if you were to cut out the spare tire well, and sheet metal it flat, you might be able to place a turbo right there. Of course its going to take a lot of fabrication, but it seems kinda of a nice setup where you don't have to do a lot of trial and error for a custom exhaust manifold for a turbo if it was placed in the engine bay of a Maxima. If I had all the time and money, i put this type of set up to the test and see if it works out. Probably will but how effective will it be. I'll be posting this in the turbo thread too, I'll basically copy and paste what I just said.
Old Feb 25, 2005 | 09:58 PM
japmaxSE's Avatar
Go Get a Life!
whaaaaaaaaat??????
That is crazy the piping would have to be tramendous I've heard of alot of crazy ideas of mounting a turbo but in the trunk damn I don't know what else to say but I have got to see it or I won't beleive it.
Old Feb 25, 2005 | 10:02 PM
Xmax's Avatar
Well I mean not in the trunk but underneath the sheet metal, I wonder if there is enough clearance under there for a turbo to fit, especially for lowered cars, but what im afraid of is when you have to go over bumps.
IceY2K1's Avatar
It's called "Remote muffler-mount turbos".
Turbo & High-Tech Performance did an article on a Squires Turbo Systems(www.ststurbo.com) kit install on an older 3.4L Toyota Tacoma. At 4psi, it went from 140bhp to 224bhp supposedly.
Interesting concept.....
Old Feb 25, 2005 | 10:04 PM
japmaxSE's Avatar
Go Get a Life!
Wouldn't that defeat the whole purpose, which is weight reduction.
Old Feb 25, 2005 | 10:09 PM
japmaxSE's Avatar
Go Get a Life!
hmmm I got some ideas now
Old Feb 25, 2005 | 10:11 PM
IceY2K1's Avatar
Here's the article:
http://i.b5z.net/i/u/1473169/f/Press/STS_THP.pdf
Old Feb 25, 2005 | 10:13 PM
Xmax's Avatar
Its probably going to be located somewhere where the well used to be if you were to cut it out, and sheet metal that area. Cuz that well is pretty deep.
Old Feb 25, 2005 | 10:23 PM
IceY2K1's Avatar
It replaces your muffler, so there is usually some pretty nice space opened up.
