Is this alright? re:Caliper Clearance
Old Mar 5, 2005 | 07:50 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
I got 300zx calipers and Dave Sz and I had trouble with the clearance. The volks were rubbing against the calipers. After trips to several different auto stores, we tried pick up some spacers. The problem with those was that there were no threads for the lugs to catch. to fix the problem, we decided to grind the calipers (iron) to be able to gain a couple more mm of clearance. It still was not enough so we let it sit overnight. Today, I called every tuner shop in the chicago area to try and get a hold of some H&R 5mm Spacers. No Go. We came up with the idea to put washers on to get the clearance. It gave just enough. The mounting surface is close to the contact that it had regularly (top pic). It seems that there is nothing wrong with the alignment or with how the car drives. there is no more tire noise than there was before.
I do have to say that the zx brakes seem way more responsive. They are currently on oem pads and rotors until I take care of some boosted toys. I also upgraded all the lines to ss.
Old Mar 5, 2005 | 10:06 PM
sagamax's Avatar
Give me a Bud Light Holmes
what was the offset and width on the volks
Old Mar 5, 2005 | 10:10 PM
slimer's Avatar
+30 and 7.5
http://toy4two.home.mindspring.com/offset.html
this site says that i lose 1mm.
Old Mar 5, 2005 | 10:59 PM
sagamax's Avatar
wow +30 offset and still couldnt clear the calipers without the washers. my 7.5 42 offset couldnt clear the z32 calipers with my 8mm spacers i have the freakin brakes sittin in my garage waitin til i can afford new wheels
Old Mar 5, 2005 | 11:02 PM
slimer's Avatar
theyre on and it seems to drive fine.
Old Mar 6, 2005 | 12:07 PM
Scruit's Avatar
U wanna try me young boy?
I would use real spacers with longer wheel studs. Or different wheels that have sufficient backspacing.
Old Mar 6, 2005 | 12:18 PM
slimer's Avatar
im ordering 2mm spacers to put on. i dont think that i need longer wheel studs.
Old Mar 7, 2005 | 10:12 AM
slimer's Avatar
bump-just seein if i can drive on this temporarily.
lowpost99
Oct 26, 2025 06:53 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
schmellyfart
Sep 25, 2015 04:47 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
