Catch me if you can... 11.5 @ 121
Old Mar 17, 2005 | 07:41 PM
  #121
Ninetein's Avatar
Originally Posted by SR20DEN
Nope. Get your facts straight people.
Oh so tell us what happened on the first engine? You did something to it because of the juice.
Old Mar 17, 2005 | 07:58 PM
  #122
SR20DEN's Avatar
VQ Wizard
Search for it. This is Mardigras thread, not mine.
Old Mar 18, 2005 | 06:37 AM
  #123
Sprint's Avatar
Search for it..
$20
Old Mar 20, 2005 | 05:21 AM
  #124
nosispower's Avatar
My stock Maxima envies you, Mardi.
Old Mar 30, 2005 | 07:36 AM
  #125
jackiss2888's Avatar
i bet mardi cant get faster
... hehe
Old Mar 30, 2005 | 07:44 AM
  #126
96SE NUH?'s Avatar
Holly crap...congrats.
Old Mar 30, 2005 | 07:46 AM
  #127
2 Da Max's Avatar
dam cant believe a maxima can run that fast
Old Mar 30, 2005 | 12:01 PM
  #128
nismos14's Avatar
§è~® f®ÈÄk
Is the car/does the car have an 00vi? are there plans for it? would the times get even better with it?
Old Mar 30, 2005 | 01:54 PM
  #129
MardiGrasMax's Avatar
MEVI. no plans for 00VI, gains at this level would not be worth the effort and money.
Old Mar 30, 2005 | 02:03 PM
  #130
Rowan's Avatar
... hehe
I bet you're wrong.
Old Mar 30, 2005 | 03:37 PM
  #131
JClaw's Avatar
Once the VQ35 block goes in, he IS wrong.
Old Mar 30, 2005 | 07:00 PM
  #132
Nealoc187's Avatar
SLOW
Gaining 5hp when you are when he is making 500 is rather pointless. There are things he can do with that money (~$300-400 for an 00vi and retrofit) to make lots more than 5hp.
Old Mar 31, 2005 | 05:59 AM
  #133
nismos14's Avatar
§è~® f®ÈÄk
oh ok, I get it now. thanks.
Old Mar 31, 2005 | 06:18 AM
  #134
JeffesonM's Avatar
living out of a maxima...
Not so start a p!ssing match, but if you consider that a 00VI provides 5hp on a 200whp engine, that would equate to 12.5hp on a 500whp engine, assuming the gains are linear. Now is 12.5hp worth it for $300-$400? Maybe not, but it is at least worth considering.
Old Mar 31, 2005 | 06:35 AM
  #135
Nealoc187's Avatar
SLOW
Heh, that is not how it works at all. Just because it gives 5hp on a 200hp engine doesnt mean it gives 10hp on a 400hp engine. You can't just multiply things like that. Also, even 12hp is diddly squat as far as gains go when you are at that power level. Still not even close to worth it.
Old Mar 31, 2005 | 07:41 AM
  #136
JeffesonM's Avatar
I agree that it is not linear, but I think in general you will see a greater benefit from small mods on an engine that produces more HP, like why people don't bother doing headwork until they start making serious HP.
Also, to add in some actual numbers, Stephen Max gained around 20hp and 15tq at various places across the powerband switching from the MEVI to the 00VI, along with better area under the entire curve. This was at 11.5 psi... I've got to believe the gains would be even better when pushing 16-18 psi. (Stephen Max's dyno thread)
Old Mar 31, 2005 | 07:47 AM
  #137
Cutler's Avatar
Any progress on the bolt issue and the machine shop?
Old Apr 2, 2005 | 09:28 AM
  #138
$50 mistake, they were able to helicoil it.
Bought some tapes and chased the holes, and using ARP lube instead of 10w30. Putting it back together today.
Old Apr 2, 2005 | 11:08 AM
  #139
subs1000w's Avatar
very good news
Old Apr 2, 2005 | 01:34 PM
  #140
I had to used a counterbore with a giude on a drill press and mill a recess for the washer to sit in the girdle. The bolts are a little short, aparently ARP has a newer set out. It took me 5 min to do, clean up took longer. Chased all the holes, used the ARP lube and they all torqued down fine. Now I need to have the pistons notched for squirter clearance
Old Apr 2, 2005 | 06:54 PM
  #141
RastaManMax's Avatar
That's slow, i can beat 11.5s no problem . Those MPH's at the end of the 1/4 are just plain disgusting. Now we need video proof that you didn't swap out the Max for a 911TT on those runs .
LEMAR
Old Apr 3, 2005 | 06:53 AM
  #142
stephenlc's Avatar
Aries will fix the pistons if you send them back.
Old Apr 3, 2005 | 07:50 AM
  #143
04BlackMaxx's Avatar
Originally Posted by Turk
Nice **** i am going to the track as soon as it opens. I am pretty excited to see what i could pull. I am hopping maybe like 14.9 around there.
TUrk:
I think there needs to be a hall of fame for the funniest signatures.
Old Apr 3, 2005 | 10:39 AM
  #144
PrinzII's Avatar
OG and counting...
Nice runs, man.
Old Dec 12, 2005 | 03:36 PM
  #145
PHAT6's Avatar
Rasta Man you sound like a d.i.c.k.
Give Mardi Gras due credit - anyone who actually turns up to race at a track instead of on the street deserves respect and anyone who can run sub-13s in a 3,000lb four door sedan deserves their *** to be kissed...though I'lll pass on the kiss.
AWESOME STUFF MARDIGRAS! YOU THE MAN!
I'm hoping to crack 15s on January 2nd, 2006 in a 1996 A32 Stillen SMX I/H/E Automatic.
C U.
Old Dec 12, 2005 | 03:41 PM
  #146
NmexMAX's Avatar
dot dot dot ...
Rasta was being sarcastic ... He was giving props...
Old therad ... hmm, I wonder how management will take to this
There are quite a few bolt on auto A32's in the 14's, so it wont be too much of an accomplishment.
Old Dec 12, 2005 | 03:51 PM
  #147
PHAT6's Avatar
I know that mate but it's my first time so I'll see if I can crack 15s and hopefully I'll be really pleasantly surprised.
Caesar runs real low 14's and he's pretty much stock - hasn't even got VI of any sort that almost all of the other 14s Maxes have. 00VI is definitely the way to go to bypass the restrictive 5,500rpm doldrums that the stock intake manifold provides (rather curses) us with.
Cheers though nmemax.
BTW - sorry RASTA.
Old Dec 12, 2005 | 06:03 PM
  #148
Requin6's Avatar
if you have an SMX you should be into the 14s no problem even with an automatic.
Old Dec 12, 2005 | 06:16 PM
  #149
PHAT6's Avatar
Here's hoping - will post asap after the race. Probably on the 4th or 5th of January next year.
Old Dec 12, 2005 | 06:26 PM
  #150
Digital's Avatar
VIP
MAXIMA AIRLINES
Today your pilot is Matt, aka MardiGrasMax. Enjoy your flight!
Congrats on the super fast time! That reaction time is AWESOME!
Old Dec 12, 2005 | 10:07 PM
  #151
JClaw's Avatar
Welcome to a year ago. His new PB is 11.40@123.
Old Dec 13, 2005 | 03:52 PM
  #152
Rowan's Avatar
wow old thread. But Mardi is worth the repost. His car is sick...
Old Dec 13, 2005 | 06:57 PM
  #153
Nickel's Avatar
hooly ****!! keep up the goood work boy!!!
Mar 12, 2020 12:06 AM
Cotozic
Jun 28, 2017 08:01 PM
05RLS2
Sep 27, 2015 09:24 PM
bbsitum
Sep 11, 2015 04:55 PM
pjgreek
Sep 9, 2015 09:30 PM
