NOS Fuel Pressure Safety switch
Thanks for the pics Tony. This was VERY helpful. Just curious, i noticed you had a 3rd line (The braided one) coming from the fuel safety switch. I am using teh dry kit, will i need to hook that up? Or just tap into fuel lines and thats it. How does this bad boy work? I dont see how it kills the fuel off. Thanks. Any more pics of would be great.
Another question
What's the min psi setting on the switch. Depending on what hp shot you're running is it a good idea to change the min fuel pressure switch accordingly or one setting will do.
Re: Another question
The FPSS is wired into the ground of the main nitrous sol. on a wet kit or the second nitrous sol. on a dry kit.
The braided line is for fuel to the my fuel solenoid. Dry kit doesn't have this. The FPS is provides ground to my main relay. This main relay powers the nitrous solenoid and the fuel solenoid. If the pressure drops below the set point, no more ground. The MSD window switch works the same way. It cuts the ground on and off.
One Max to Envy
Why did you choose the wet over the dry kit and what's the pros and cons between the two. I have a extra set of intake plenum and manifold and was considering the wet kit. This will give me enough time to tape the plenum for the foggers before installing to reduce down time
Re: One Max to Envy
Wet kit has many advantage over dry kit.
1. It's easier to tune.
2 I don't have to mess with fuel pressure or the fuel pressure regulator.
3. I don't have to worry about maxing out the fuel injectors or the fuel rails...etc. Direct port kit basically takes half of the OEM fuel system out of the equation. However, I do still have to worry about the fuel pump and fuel lines.
4. All the cylinders get the same amount of nitrous. My tuner blew 2 Supra motors using a dry kit, but didn't have anymore problems when he switched to direct port kit. His Supra was running 9s. The first few cylinders will always get more nitrous than the rest on a dry kit. This cause possible lean condition for the first few cylinders.
The only draw back of direct port kit is the installation. Takes more time.
Re: Before I forget
You have to change jets on each fogger, but I have more control over how much fuel than dry kit. On the dry kit, you control how much fuel via the adjustable fuel pressure regulator.
Is it easy to change your HP shot setting, do you have to change each individual nitrous and fuel foggers
Forge277
Jun 13, 2016 09:26 PM
