Anyone use PC based Diagnostic Software
Old May 18, 2005 | 06:29 PM
my350z8
Does anyone know of or use PC based diagnostic software to read the codes, monitor/datalog the sensors & fuel map on a 96 Max? I have found some that will work on my 91 300Z.
Old May 18, 2005 | 06:38 PM
MrGone's Avatar
not on a 96 max, but yes
Old May 18, 2005 | 06:43 PM
maxwannabenow's Avatar
I am interested in this for my 2000 Max. What software and hardware do you need?
Old May 18, 2005 | 08:43 PM
killerVQ30DE's Avatar
Costs $AU137
http://www.plmsdevelopments.com/consult_if.htm
These interfaces consist of a cable which connects between the serial port of a laptop and the Consult Port of Nissan vehicles. Software is then run on the laptop which allows various diagnostic functions to be accessed. A genuine Consult connector is used.
It includes the following features:
* Real time monitoring of RPM, speed, injector pulsewidth, injector duty cycle, TPS position, AFM voltage, speed, idle valve opening %, IGN timing, coolant temp, battery volts etc. All displayed on nice pseudo-analog gauges.
* Basic data logging on all parameters (data is saved to a .csv file so you
just need to load in into Excel to display/graph it).
* Read and reset fault codes
* Active tests like �power balance� (knocks one cyl out at a time), fuel
pump on/off, VCT control, temporary changes to values for coolant
temp, IGN timing, AAC valve (for idle adjustment) etc.
* ROM read
Confused Its hard to read what each gauge does from that screenshot - it does say its just in blue
There's an small (60x35x28mm) interface box in the cable which converts the data. The interfaces have been tested on a list of vehicles which is growing by the day but includes the following:
* AUS 200SX S14 (SR20DET)
* AUS 200SX S15 (SR20DET)
* AUS Maxima A32 (VQ30DE)
* AUS Pulsar N15 (GA16DE)
* AUS NX/NXR Coupe (SR20DE)
* JDM 180SX S13 (SR20DET)
* JDM Silvia S14 (SR20DE)
* JDM Silvia S15 (SR20DET)
* JDM Pulsar GTi (SR18DE)
* JDM Bluebird U14 (SR18DE)
* JDM Bluebird U15 (SR20DET)
* JDM Skyline R32 (RB20DET)
* JDM Skyline R32 GTR (RB26DETT)
* JDM Skyline R33 (RB25DET)
* JDM Skyline R33 (RB20DE)
* JDM Skyline R33 GTR (RB26DETT)
* JDM Skyline R34 (RB25DET NEO)
* US 300Z Z32 (VG30DETT)
* US Sentra B13 SE-R(SR20DE)
* US Maxima A32 (VQ30DE)
* UK Almera N15 GTI (SR20DE)
* UK 200SX S14a (SR20DET)
* UK Micra K11 (CG13DE/CG10DE
* FRA 200SX S14 (SR20DET)
* GER Almera NX (GA16DE)
* GER 200SX (SR20DET)
Costs $AU137
Old May 18, 2005 | 10:49 PM
Larrio's Avatar
The Definitive AE Master
I use this:
www.autoenginuity.com
however for some reason I can only get it to work on 01+ maximas and other OBD-II vehicles
it does not work for me on the following vehicles 95-00 maximas
Old May 19, 2005 | 07:36 AM
01Black20th's Avatar
how do u go about reseting the check engine light on a 01?
Old May 19, 2005 | 09:13 AM
98maximaSS's Avatar
is it just me or does that seem really cheap? its only $103.XX for the software
Old May 19, 2005 | 10:10 AM
Larrio's Avatar
killer: can that device clear engine codes?
Old May 19, 2005 | 10:16 AM
Jatan's Avatar
http://home.iprimus.com.au/tkolo/datascan.htm
Old May 19, 2005 | 10:44 AM
Larrio's Avatar
yea, i read the other site. Interesting how its just like the conzult which from my understanding emulates the nissan consult
Old Jun 1, 2005 | 10:42 PM
Ants97SE's Avatar
I've used this one in the past... it's worked pretty well for me.
http://www.obd-2.com/
Old Jun 1, 2005 | 10:56 PM
DAVE Sz's Avatar
Hooooooonda.....
^ I have that one. I also have digimoto and a few others. They work well but our POS is so slow that it's sometimes as pain to do live data monitoring. I can hook my laptop along with the interface box to other cars and many are much faster and have better samoling rates than out POS 8 or 16 bit ECU. For clearing codes it's awesome. Click a button and that's it.
Apr 16, 2020 05:15 AM
9aj9
Apr 5, 2020 12:11 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
magiconthetire
Oct 26, 2015 09:03 PM
