Help with oil pressure and temp gauge install
Old May 23, 2005 | 08:51 PM
maxspeed96CT's Avatar
The original VQ...
Ok , i am going to be hooking up a electrical oil pressure gauge i got this job down pat from the pics 1max2Nv has posted before.
but I also want a oil temp gauge tho, can i hookup all 3 senders to the one oil like?
for example can i run a line up from the stock oil pressure sender location , and then use a fitting for the stock sensor, the oil pressure sender , and the oil temp sender + the line? or will this be to much hooked up t one line?
I want to set it up like the pressure sender in this pic, but i would also like a temp sender to the fitting....
Old May 24, 2005 | 02:06 PM
RA030726's Avatar
I'm nutty for Nissans
i think the temp sensor is better suited when installed in the oil pan.
Cotozic
Jun 28, 2017 08:01 PM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
