tranny flush
Old May 24, 2005 | 09:21 PM
Teufelhunden's Avatar
tranny flush
my car is now at 30k and i need to get the tranny flushed.
the guy at the shop said 40 bucks for regular drain and fill, and 100 bucks for the tranny flush with ATF. now, should i go cheap and just get the drain and fill? or shell out 100 bucks for the ATF flush? would there be any difference between these two? i dont want to get the expensive one if there isnt that much difference between these two. thanks.
Old May 24, 2005 | 09:26 PM
dubsonmax's Avatar
it really depends on the condition of the tranny. if it has been maintained good then it should be completly flushed, if not just the reg cheap drain and fill. and there is much difference in the two.
Old May 25, 2005 | 04:35 AM
njmaxseltd's Avatar
At only 30K a drain and refill with ATF should be fine.
If you'd like to switch it over the synthetic fluid, being it still has low miles on it, then a complete flush would be best. Synthetic fluid does has it's benifits over regular tranny fluid. There is a lot of good information about this topic in the fluids & lubricants section of this board.
Old May 25, 2005 | 09:06 AM
thanks guys, ill check the fluids section like you mentioned. mods, can you move this to fluids section? thanks
Old May 25, 2005 | 11:40 AM
Bobo's Avatar
I think you've got this a$$ backwards!
user 11122324
42
Jul 18, 2022 03:35 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
RWCreative
Sep 21, 2015 11:01 AM
pktaske
Sep 4, 2015 08:40 AM
