Atten: SprintMax & Synki
Old May 16, 2001 | 09:36 PM
mtrai760's Avatar
'Trynna' is not a word
Need your help. What was your Jcwhitney kit missing that you needed to get your NOS going? Mine will be here in 2 days. Thanks for the help. Matt
Old May 17, 2001 | 05:04 PM
mtrai760's Avatar
bump
Old May 17, 2001 | 05:10 PM
Sprint's Avatar
it has everything you need to run it..
however you are going to need some other stuff
Fuel Pressure gauge
EGT Gauge
A/F Gauge
Window Switch
Brass Fitting (for Fuel Pressure Switch)
Old May 17, 2001 | 05:12 PM
Sprint's Avatar
I am installing mine without the Fuel Pressure Gauge and EGT Gauge
Old May 17, 2001 | 08:14 PM
Synki's Avatar
First, you will need to get some Teflon Paste. I got mine from a Home Depot but you can find this at *some* local parts store. Everything you *really* need is supplied. Bsides from the Teflone Paste, get:
-Must-Brass Fittings for the Fuel Pressure Safety Switch (1/8 Threading).
-Must-A/F Gauge
-Optional-Dual Gauge Pod or a Blitz In-dash 3 gauge kit.
-Optional-EGT Gauge(You will need to order a probe as well, the gauge kit didnt come with one)
-Must-Nos pressure Gauge, i got the NX gauge for $23 bucks, it mounted to the bottle
-Must-Window Switch (MSD is the cheapest)
-Optional-Purge Kit (This is more for show)
-Optional-Bottle Heater (Warms the bottle up for proper temp)
-Optional-Fuel Pump )If you want to run bigger then a 70 shot)
-Optional-Blow Off Down Tube (Releaves the NOS pressure to the outside of the car rather in inside)
This is it, It cmoes with all wires (more then plenty), switch, and all the connectors and "T" taps.
Old May 17, 2001 | 09:13 PM
mtrai760's Avatar
Thanks guys
Old May 17, 2001 | 10:13 PM
mtrai760's Avatar
Hey Synki
Did you ever get that link to the cheap window switch? I'd appreciate it if you can share Are you bumping up your fuel pressure, or letting the FPSS watch over it? Thanks in advance.
Old May 18, 2001 | 10:11 AM
Synki's Avatar
Re: Hey Synki
I got the info for the window switch but the guy is backed up. I got the info from MardiGras. You can get the info on my other thread:
http://forums.maxima.org/showthread....5&goto=newpost
It is the last reply i have.
Right now, i have the 50 jet in. Well, i can get a MSD window switch from my job for like $75 or so but then i hav eto maiol it into MSD and have them modify it for an extra $30 or so.
I have the bypass fuel jet in right now. This raises the fuel pressure a little. Maybe 3-5lbs extra. I do have my FPSS in. I think that is a must if you want to prevent from spraying with little gas. You can get diff bypass jets to either raise your fuel pressure or lower it. It can only do so much before a new fuel pump is needed. I hope this helps.
MikeyMax
Feb 27, 2002 12:46 PM
mtrai760
May 30, 2001 03:52 PM
