How to fix door sag?
Old Jun 13, 2005 | 05:24 AM
johnson's Avatar
My driver side door is starting to get harder to open because it feels like its sagging. Now it takes a little push or pull to get it open. Do I just need to re-tighten the bolts or is it something else?
Old Jun 14, 2005 | 11:53 AM
Slider's Avatar
You can adjust it at the hinges, also you can adjust the door striker plate.
Old Jun 14, 2005 | 06:48 PM
njmaxseltd's Avatar
You might need new hinges, if you weren't up on lubricating them over the years, they ware out. You can check the hinge condition by opening the door and pulling up and down to see if there is any play. If you feel play, the hinge needs to be changed to correct the sag. Check both the upper and lower hinge to see if they both have play.
Old Jun 15, 2005 | 03:07 AM
panda_1's Avatar
jus yesterday i was thinking on how to adjust the driver door, you guys rock!
Old Jun 15, 2005 | 07:32 AM
OOmaxSE's Avatar
mine is acting the same, but i heard you can just replace the bushings. if anything get new hinges and your door will open and close like a new car.
Old Jun 27, 2005 | 02:49 PM
maxwannabenow's Avatar
I have the same problem with my Max. Just bought the new hinges but haven't got them on yet. Dealer said that there is not a bushing kit. The hinges cost about $25 each for the front drivers door.
Old Jun 29, 2005 | 08:43 AM
OOmaxSE's Avatar
it's a pain in the aas to put it in though. my door closes like it's gonna break
Old Jun 29, 2005 | 09:20 PM
CanadianMoFo's Avatar
I put a washer in behind one of the lower door hinge bolts on a VW. The hinge on the vehicle side, not on the door itself. It pushed up the door back into its regular position. I drove it for a couple more years like that and never had a problem. Worth a shot for the 25 cents it might cost you.
CM
Junebug1701
Sep 25, 2015 01:54 PM
JoshG
51
Sep 21, 2015 10:41 PM
lkiller123
Sep 21, 2015 03:00 AM
ajahearn
Sep 19, 2015 03:03 PM
