Wanna hear bad luck....i cant win!!!!
Old Jun 21, 2005 | 06:22 PM
bobjohnson's Avatar
Blazin......
This is All over Basic Maintence & Using a Family Mechanic...
First Wheel Bearing:
5 Months ago I needed a R-side Wheel Bearing.
Bought New At Advanced Auto Parts.. 180ish
Mechanic Installed 300 b/c its the press in style.
.......................................... So Approx $480.
First Brakes:
2 Months later I purchased very Slowly my New Brakes.
Brembo Rotors $140, Porterfield RS pads. $110, Fit clips $14.95
Easy enough, I installed it....... So Approx $260.
2nd Wheel Bearing:
Well Here we go..... Crapy wheel bearing Failed...
Returned that one-$... Paid $20 More and got one from Somewhere else.
Mechanic Labor To install it.... So Approx $200.... b/c its the 2nd one.
$960.00 so far....
NEXT My Brakes go bad. Everything goes to ****.
He <Mechanic> claims i installed them incorectlly... haha right.
So I got Nissan 70.00 Factory Pads, Rotors Turned , and New Fit clips again.
THIS TIME I PAID HIM to do the work.. Approx 270 with labor..
AutoTire Day <last thurs.>
The Local Speed shop Recommended Them For simple Tire Installation..cool.
Put My car on the Rack. They could SHAKE MY WHOLE WHEEL 1/2 Inch Both Ways. (YES same Wheel Bearing side)
Turns out.. My MECHANIC. DIDNT TIGHTEN my AXLE Nut.. wtf?
SO They Tighten It. Oh What do ya know..
Brakes are shot again...
I will agian Proceed to Install the 3rd Set of Pads this YR. And Get My Rotors Turned ONCE AGAIN...
All together i sucessfully wasted about
960+270+200ish for new crappy brakepads/rotors turned.......
OH about $1,500.00 On THis RIdiculious Car...
OH plus+ i may need another wheel bearing in the nxt yr b/c the axle Nut was so loose the bearing got Much More Wear on it..
man where do i win....... i almost wanna H-thing
Old Jun 21, 2005 | 06:39 PM
THT's Avatar
THT
Throbbing member
For a six year old, you have a surprising amount of money. It's about time for you to find another mechanic.
Old Jun 21, 2005 | 06:44 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Very true....
Old Jun 21, 2005 | 06:48 PM
bobjohnson's Avatar
Blazin......
Damn that Had NOTHING to do w/ this post....
CystumMax does have a 6yr old as his avatar... his own prob though..
THis place must have gotn filled w/Immature boys Since ive Last been...
Old Jun 21, 2005 | 06:54 PM
Rick James's Avatar
How exactly are you brakes going bad?
Old Jun 21, 2005 | 07:10 PM
bobjohnson's Avatar
Blazin......
My mechanic didnt tighten down the axel nut... either time when installing the wheel bearing.
Once they(autotire) Tightened down the Axel Nut THen the Rotor/Pads were aligned again... But it had been loose ,therefore the wear on the rotor and pads was off aligned.
It sounds horrible when i stop... grinding scraping... this is because everything is in place and ALigned. Not all loose at the Axel and everywhere.
Old Jun 22, 2005 | 04:25 AM
CystumMax's Avatar
Do you watch family guy?
I thought my english was bad, but look at this guy.
you replace your brake, and you call that a problem?
Which one of these things are you?
Old Jun 22, 2005 | 05:42 AM
konak85's Avatar
get a new mechanic. make sure he's SAE certified.
Old Jun 22, 2005 | 07:55 AM
NmexMAX's Avatar
dot dot dot ...
You're complaining of this site when you should use it instead of b!tching about how bad your mechanic took you for .. A lot of that work you could've done on your own and saved some money. Those are expensive brakes too ... Bearings don't go that easily nor do they go that fast, your mechanic figured out how to you ... and bearings hey " works everytime" he probably tells his friends. I would've said the same thing about your age ... change it, maybe you'll be looked upon dirfferently maybe not, I don't care. What's with a little humor, he also suggested, just like 100% of the people that have posted so far, to get a new mechanic because he's you and you seem to like it. Family mechanic ... Pressing bearings isn't that hard ($200+ )
Old Jun 22, 2005 | 08:29 AM
Bobo's Avatar
As the old saying goes, a fool and his money are soon parted. Do you own a Haynes manual and any tools? If not I suggest you start with that. Find a mechanic who is competent if, in fact, you aren't!
Old Jun 22, 2005 | 09:12 AM
paulfromchicago's Avatar
CystumMax, is that chuck norris with the long dreads
Old Jun 22, 2005 | 12:32 PM
CystumMax's Avatar
Yes i think so....
But I am not 100% sure...
Maxboy23
55
May 1, 2025 06:09 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Andy29
Sep 29, 2015 05:32 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
I<3 A32's
Sep 10, 2015 11:07 AM
