View Poll Results: Which Tranny in a 4th gen with a full 3.5 swap do you think would be faster/better?
4th Gen 5 Speen Manual
22
53.66%
6th Gen 5 Speed Auto
39.02%
Little difference
7.32%
Voters: 41. You may not vote on this poll
4th Gen Manual tranny vs. 6th Gen 5-speed Auto
Old Jul 28, 2005 | 09:05 AM
Hitmanforprez's Avatar
Which transmission in a 4th gen Maxima with a full 3.5 swap do you think would be faster?
Not worried about having a manual vs auto-tragic, just what you think is faster/better
Old Jul 28, 2005 | 09:08 AM
NmexMAX's Avatar
dot dot dot ...
The 5M from the 4th gen since it's more effecient.
6M is better for gas mileage, but not by much, and is also geared pretty high (not agressive). Only @ speeds 110-120 + will it have an advantage, and it's a small advantage at that.
MPH @ 6500
------5M----------6M
1st ---40----------41
2nd --70----------67
3rd --102---------94
4th---137--------124
5th --164--------164
6th--------------208
RPM @ 75 mph cruising
5M--------2961
6M--------2340
Old Jul 28, 2005 | 09:10 AM
I was talking about the 5 speed Auto in the 6th gen not the 6 speed Manual
Old Jul 28, 2005 | 09:19 AM
NmexMAX's Avatar
dot dot dot ...
In that case still the 5M since it's more effecient and works more easily as far as electronics are concerned.
--------5A--------5M
1st ----44----------40
2nd ----67---------70
3rd ----103--------102
4th-----152--------137
5th ----201--------164
5A--------2420
5M--------2961
http://www.forums.maxima.org/showthread.php?t=402818
Old Jul 28, 2005 | 09:29 AM
So form what I'm reading you think the 5M would be better on gas how about just based on speed? Looks from the ratios it could be tight, no?
Old Jul 28, 2005 | 09:36 AM
NmexMAX's Avatar
dot dot dot ...
Yes, but the 5M is more effecient therefore more power will be getting to the ground, though the 5A will be more consistent, the 5M will depend on the driver.
Also, the 5A is a whole new set of as.s bags considering the wiring, this is of course if you're transplanting into a 4th gen.
Old Jul 28, 2005 | 09:54 AM
SPiG's Avatar
SomePsychoGuy
Swapping in a 5A would be a PITA. The wiring would be a nightmare. You would have to convert to a gated shifter. I can't even imagine it being worth it to convert from 4A to 5A.
The 6M might be worth it with a more aggressive final drive. What maxima or even a 350Z would be going 208mph? That is ridiculous. The gearing on the 6M is just not spaced well and has a lot more drivetrain loss since it has 8 gears to be constantly meshed (6 + 2 reverse) as opposed to the 5 the 5M has.
The best swap is the 00-01 5 speeed. It is the strongest tranny while still being pretty much bolt on.
Old Jul 28, 2005 | 09:58 AM
NmexMAX's Avatar
dot dot dot ...
Also, the 6th gen has a more agressive F/D, sorry, I did not put that into consderation, as those comparisons are with the 5.5g 6M, but it doesn't matter since he was asking about the 5M and 5A ...
5g 5M =
Old Jul 28, 2005 | 07:19 PM
MaximaSpd85's Avatar
Originally Posted by NmexMAX
MPH @ 6500
NmexMax, u gots some pretty fast maxima friends!! I always knew the VQ had it in her, go VQ
Old Jul 28, 2005 | 08:23 PM
d00df00d's Avatar
Old enuf to pick his own gears
I'm sorry... anyone who voted for the auto here just has no idea what they're talking about.
Heavier, MUCH more drivetrain loss..... 'nuff said.
Old Jul 28, 2005 | 10:50 PM
RHMax's Avatar
Newbie just Registered
From the thread title, it's a little miss leading with the choices between 4th gen 5mt versus 6th gen 5at. I paused for a couple of seconds, my mistake. Since you are doing a swap, get manual either 5mt for speed or 6mt better mpg. And like NmexMAX wrote:
Old Jul 29, 2005 | 11:31 PM
rome06's Avatar
5A--------2420
5M--------2961
im confused are u saying 2nd gear on a 4th gen manual goes 70mph???
Old Jul 30, 2005 | 01:41 AM
SPiG's Avatar
SomePsychoGuy
Yeah that is about right at red line.
Old Jul 30, 2005 | 07:43 PM
rome06's Avatar
wtf
mine goes to like 63 or something at the redline of 2nd gear on a MANUAL ...??? am i missing something?
Old Jul 30, 2005 | 09:23 PM
04BlackMaxx's Avatar
Maybe its more of a question if you want to shift or not
Old Jul 31, 2005 | 09:25 AM
rome06's Avatar
no thats really kind of weird.....i know for a fact that the fastest i had my car up in 2nd gear hitting the rev limiter was 62/63mph
Old Jul 31, 2005 | 09:43 AM
laylow1988's Avatar
you should get the jwt ecu extended rev then
Old Jul 31, 2005 | 05:04 PM
rome06's Avatar
oh you have to get the ecu upgrade for it to go 70mph redlining 2nd gear??? OR is that supposed to be stock on a MANUAL 97' SE to hit 70 in 2nd b/c if it is than my car is foooked
Old Jul 31, 2005 | 06:28 PM
rome06's Avatar
maybe my gauges or something is messed up....idk i have shiitty tires, bad knock sensor, and bad cv joints/axles if that does anything ??
Old Aug 1, 2005 | 06:41 AM
NmexMAX's Avatar
dot dot dot ...
It's theoretical , and derived from given equations .... It doesn't take into account tachometer/speedometer error & drag, sag .. etc.
Old Aug 6, 2005 | 05:23 PM
Jesse H's Avatar
Regardless of which is faster, I prefer using both hands and feet to drive.
Old Aug 8, 2005 | 04:42 PM
DrKlop's Avatar
Driving is the next best thing
Manual gives a lot more control and it is much more fun to drive. (Of cause if you know how to drive it)
I also have unconfirmed information that manual transmission transmits more power to the wheels and it can be shifted quicker than your automatic.
Old Aug 8, 2005 | 05:26 PM
killerVQ30DE's Avatar
Manual obviously puts more power to the ground as its a mechanical tranfer of power rather than an automatic which hydraulic based.
IIRC manual has a 15% power loss and Auto has 23%
Old Aug 8, 2005 | 06:21 PM
theANSWER's Avatar
just get the manual it's funner to drive
Old Aug 8, 2005 | 06:33 PM
nirvana4all's Avatar
umm just a question, but why do you want to do this? if you have a manual, it will be much easier to just stick with it, and it will be faster if you are a decent shift...auto likely to last longer for the poor driver/shifter...and likely more work installing if ya think about wiring and such.
Old Aug 9, 2005 | 09:41 PM
JClaw's Avatar
VQ35 and 5-speed tranny in a 4th gen is a ton of fun, unless torque steer bothers you.
Old Aug 10, 2005 | 01:29 PM
ColdSHO's Avatar
why not an 5spd ae 01 or the 5spd canadian 00-01 trans , i know theyre harder to find but the lsd would be worth the extra trouble imo.
Old Aug 10, 2005 | 01:37 PM
NmexMAX's Avatar
dot dot dot ...
Only when turning....
Old Sep 5, 2005 | 06:38 PM
OOmaxSE's Avatar
curious to know why 6M tranny from the 5.5g isn't put into consideration? am i missing something? i think i'll want to do this swap in the near future and it would be much easier to stick wiht my 5M but the 4th gens with 3.5L will feel much more of a power diff compared to my 5th gen with 3.5L
stevesmax
Dec 17, 2020 11:57 AM
Matt93SE
May 24, 2019 02:58 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
