longer wheel studs?
Old Jul 30, 2005 | 09:13 PM
AnDyMaN's Avatar
longer wheel studs?
im gonna get spacers, and im not sure where to get longer studs..... i dont need the whole hub thing w/ studs right? my friend has a minivan (aka white stallion ) and his stud broke, so he just hammered out the old ones , and put new ones on.... thats all there is to it righT? just making sure, but, where would i find studs that will fit my car, but are longer?
maybe ill post htis in the wheels/tire forum..............
Old Aug 3, 2005 | 11:52 AM
wed3k's Avatar
http://www.optauto.com/index.htm?par...5&deptid=12523
Old Aug 5, 2005 | 06:50 PM
RA030726's Avatar
I'm nutty for Nissans
if you get over a 10mm (3/8") spacer then yes you need longer studs. But its always good to get longer ones any how. Some spacer kits have longer studs included while others have the spacer and studs all ready together and you use the stock studs and open ended lugs to attach the who shabang. Thats usually for 20+mm spacers. You need to check the hub of the rim for compatability for certin spacer kits. If you need longer studs then check locally first.
Old Aug 6, 2005 | 11:56 PM
99BlkSE5spd's Avatar
call up some local auto parts stores, they should have the studs
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
