What should I do?
Old May 23, 2001 | 03:41 PM
JDwyer2821's Avatar
I just came back from the transmision place and the noise I hear from my max is a bearing gone bad in the tranny. The mechanic I talked to said to replace all the tranny seals and bearings it would cost about $1100. He gave me the names of other mechanics that will look for a nice condition used tranny which would be cheaper. Man I just had a new clutch in three weeks ago. What should I do? I have a 1992 maxima SE 5 speed with 130000. Also he said the gears feel strong and go in with ease.
Thanks Jon
Old May 24, 2001 | 06:09 AM
sinewave's Avatar
When exactly does it make the noise? Is it only when you press in on the clutch pedal? Did your mechanic say that it might be the throw-out bearing?
If it is the throw-out bearing, it should have been replaced with the clutch.
Old May 24, 2001 | 06:27 AM
deezo's Avatar
That price is kind of high. Shop around.
Old May 24, 2001 | 09:27 AM
JDwyer2821's Avatar
I Think he said it was one of the trans-axle bearings. Its only when the clutch is up, when the clutch is all the way down it goes away almost
Old May 24, 2001 | 09:57 PM
Matt93SE's Avatar
STFU n00b!
Unfortunately this is a somewhat common problem in these cars. JustinMC had this happen to his, and I've heard of a couple others.
the price should be closer to $600 for that job, not $1100.
BTW, that $600 was the price of a full rebuild for a 5 spd tranny, not just replacing a bearing and the seals. I believe all the bearings inside the tranny were replaced, inlucing the seals.
check around with some other tranny shops and see what they quote you...
