automatic guys..atf fluids..what the hell?..
Old May 28, 2001 | 06:01 PM
buss95max's Avatar
ive read post about switching to redline d4 atf. but what are the real benefits of doing this? is it worth $9 a quart? i was going to buy some mobil 1 atf, cuz at the mobil gas station its only 3 bucks a quart. which isnt too bad. has anyone gone to the track and gotten improved times just by switching atf? how about some butt dynos?
is everyone switching just cuz everyone else is doing it?....i dont want redlineoil.com stats..i want real life everyday driving facts....
Old May 28, 2001 | 06:46 PM
LoveSick's Avatar
The reason why Redline costs 9 bucks and the Mobil 1 costs 3 was because Redline is synthetic. Mobil 1 sells synthetic which is on par with redline. If you are to change it, change it to whatever brand you want, but make sure its synthetic. 100% synthetic!
As for improving times, I don't know. It helps protect the trnasmission. But after changing mine, I felt the car shifted alot smoother and quicker. Go figure.
Old May 28, 2001 | 09:10 PM
buss95max's Avatar
the mobil 1 i saw was synthetic..i went to autozone and saw the same atf for 5 bucks a quart...so mobil 1 and redline are the same?..hmmm..something to think about..
Old May 28, 2001 | 10:10 PM
1MAX2NV's Avatar
It's synthetic that's why.
Synthetic ATF will last 2X longer than dino oil and less prone to breakdown at high temp. Mobil 1 ATF for $3 qt is a really good price. They do usually go for $5 a quart. I had my first flush at 20K mile with Redline D4 ATF. I just recently flushed it again (45k) with Mobil 1. I couldn't tell any difference between the two. I would just go with Mobil 1 because it's cheaper and more readily available. I would flush the ATF every 30k if you drive hard and want your auto tranny to last more than 100K.
Old May 28, 2001 | 11:48 PM
buss95max's Avatar
1max2nv
so can i just drain out my dino atf, and refill with syn atf? or is going to jiffy lube for a flush a must?..i think eric L said it was like ~80 bucks..
Old May 29, 2001 | 08:41 AM
1MAX2NV's Avatar
Re: 1max2nv
Flush is a must. Drain and fill is not good enough IMHO.
I get my flush done at
http://www.vioc.com/index_flash.asp
Old May 29, 2001 | 09:41 AM
AntGVR4's Avatar
here
When i swapped my VB about 7K miles ago i just added Mobil 1 Synthetic ATF ...
Drain the entire thing ? i'm not gonna do it ...
I must say the synthetic holds up real good to the pounding i put on the tranny
Ant
MaxStock
Dec 5, 2016 05:19 PM
ef9
Oct 4, 2015 08:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
Andy29
Sep 29, 2015 05:32 AM
